Re: Another "what to swap" question
[Re: poorboy]
#1246029
06/06/12 08:11 PM
06/06/12 08:11 PM
Posts: 597 West Newbury, MA
MOPAR_AMC_FAN
West Newbury, MA
Thanks for the info so far!
As far as what I want from the truck if I got it, I'm looking for a driver/cruise night car (or truck as the case may be). I'd take it to shows, but it doesn't have to be perfect. I like to drive my cars. I'd probably run some 15" rims with 60 series tires or somthing. Nothing crazy. I have other projects for that. I don't need it to be scraping the ground, but maybe a little lower in the front, or maybe a little lower all around.
For skills and budget, I have some skills and a small budget. I've done a little welding, but can always use some more practice, built an engine or two, redone suspensions, etc. I don't have a ton of extra cash, but can always save or sell some parts to get some more.
I guess I could just redo the stock suspension, try to drop it in the front, maybe add some discs, etc. Otherwise, I could try to find a late-model frame to fit it on or a stub that would work.
[Re: MOPAR_AMC_FAN]
#1246030
06/06/12 10:18 PM
06/06/12 10:18 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
I like the mustang II style streetrod frontends alot, I have one under my race truck and have one under the 34 dodge roadster PU that I am doing right now, plenty of after market parts available for them(dropped spindles,bigger brakes,power racks). but if you want to keep it all mopar, I would find a reasonably priced Dakota chassis and drop your truck on it and then you have a great modern chassis,steering and brakes. its not that hard to make cab and bed mounts. I have my 46 coe mounted on one and I have another one that will be going under a 47 dodge panel truck. or you could just use the dakota front clip, just cut it off and graft it to yours Ron...
[Re: dogdays]
#1246032
06/07/12 09:35 PM
06/07/12 09:35 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
Go with a Dakota frame. You can splice the forward section of the dak frame with the rear 57 frame and get whatever height you want. This is what I did on my 57. I would be glad to answer any questions on how to do it on the cheap.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: rattler]
#1246033
06/08/12 04:54 AM
06/08/12 04:54 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
following along,,,,,, 57 are hard to find as are 37 plymouth trucks,,,ide take either,.,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
