Clearances #1245781
06/05/12 12:54 PM
06/05/12 12:54 PM
Forest Grove,Oregon
beepbeepdon Offline OP
Forest Grove,Oregon
Loose or tight?......Any opinions?
main bearing clearances .00275
rod bearing clearances .00250
Re: Clearances [Re: beepbeepdon] #1245782
06/05/12 02:06 PM
06/05/12 02:06 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
race motor or street driver??
Re: Clearances [Re: dartman366] #1245783
06/05/12 02:21 PM
06/05/12 02:21 PM
Forest Grove,Oregon
Forest Grove,Oregon
Sorry about that....Race only...Stock steel crank.... 7.100 K1-Tech Billet 4340 H-Beam Rods
Re: Clearances [Re: beepbeepdon] #1245784
06/05/12 02:27 PM
06/05/12 02:27 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
on my 408 Terry set the clearances at .0030-mains,,,.0028 on the eagle rod's, so you are pretty close in my opinion.
Re: Clearances [Re: dartman366] #1245785
06/05/12 02:29 PM
06/05/12 02:29 PM
Forest Grove,Oregon
Forest Grove,Oregon
Thank you for your input...I really appreciate it
Re: Clearances [Re: beepbeepdon] #1245786
06/05/12 02:48 PM
06/05/12 02:48 PM
That is tight in my opinion, tighter than I like to use in a race only motor If you used a thin oil,5W20 or zero weight, you'll probally be fine with those clearances, make sure you have some heat in the oil before racing it though I like to have between .003 to .004 on the mains and .003+ on the rods using the 2.200 rod journal size, bigger on the stock Mopar rod sizes, 2.375 I use 5W20 or 5W30 wt. oil only in all of my motors now, street or race only
Re: Clearances [Re: Cab_Burge] #1245787
06/05/12 03:02 PM
06/05/12 03:02 PM
Forest Grove,Oregon
Forest Grove,Oregon
Thanks Cab...The reason I am asking is that Joe Gibbs recommended a 5W40 Synthetic (DT40) based on those clearances....I am not necessarliy second guessing them but just wanted to get various opinions......Long story short....I lost my cam (flat tappet/solid)last year and I feel it was due to a poor choice of oil ( on my part)....So after an expensive rebuild I DO NOT want to take any chances with oil selection again...Hence the choice of zinc "rich" Joe Gibbs oil.........Man I should have gone roller...DOH!!!!
Re: Clearances [Re: Cab_Burge] #1245788
06/05/12 03:48 PM
06/05/12 03:48 PM
USA
BB Dart 69 Offline
BB Dart 69  Offline
USA
I use 30wt oil,
Re: Clearances [Re: beepbeepdon] #1245789
06/05/12 05:20 PM
06/05/12 05:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That almost exactly what my 416 clearances are...
I normally run .003 and .003 ... I wouldnt worry
about it... if you run heavy oil you'll see high
pressures
Re: Clearances [Re: MR_P_BODY] #1245790
06/05/12 06:19 PM
06/05/12 06:19 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The book says .002 to .003 so your perfect. Is that a bad thing?
2011 Drag Pak Challenger
Re: Clearances [Re: MR_P_BODY] #1245791
06/05/12 06:48 PM
06/05/12 06:48 PM
Forest Grove,Oregon
Forest Grove,Oregon
Thanks Mr P_Body
Re: Clearances [Re: rickseeman] #1245792
06/05/12 06:49 PM
06/05/12 06:49 PM
Forest Grove,Oregon
Forest Grove,Oregon
It is a good thing...nice to know I'm in the safe zone huh?
Thanks for the help
Re: Clearances [Re: BB Dart 69] #1245793
06/05/12 07:01 PM
06/05/12 07:01 PM
I use 30wt oil,
I'll share a little information on oil wieght based on past dyno testing, motor #1 with 30 WT oil saw a ten HP increase in the oil temps being 130 F versus raising them to 160 F Motor # two and later saw no HP or Torque differences with both 5W20 WT and 5W30 WT between 90 F and 200 F A ten HP change at the track can throw your dial off a bunch
