Heater hose bracket - 1968 Charger #1245452
06/04/12 07:14 PM
06/04/12 07:14 PM
Santa Cruz, California
Lefty Offline OP
Lefty  Offline OP
Hi all,
I'm building a 68 Charger (non AC) and am having a bit of trouble finding a decent fender mounted heater hose bracket. I just received one purchased from Valley Vintage Auto Parts and it is too small to actually fit two 5/8" heater hoses side by side in the space provided. Is that how the factory built them? Any info on where to find a correct sized repro? Thanks.
This is what I bought -
http://www.ebay.com/itm/66-67-68-Coronet...=item4837ea2ec5
Re: Heater hose bracket - 1968 Charger [Re: Lefty] #1245453
06/04/12 07:23 PM
06/04/12 07:23 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Shouldn't 68 have the bracket on the valve cover??
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Heater hose bracket - 1968 Charger [Re: Prodart440] #1245454
06/04/12 07:38 PM
06/04/12 07:38 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
68 BB does not use a fender bracket. It uses two brackets - the one like you purchased and one that attaches to the passenger side valve cover. Something like this.......
Re: Heater hose bracket - 1968 Charger [Re: 70mopes] #1245455
06/04/12 08:38 PM
06/04/12 08:38 PM
Lefty Offline OP
Lefty  Offline OP
OK, bracket mounts to the alternator and the hole I see in inner fender is for one of the washer bottle mounting ears. Thanks.
Still, the alternator bracket is too small to get two 5/8" heater hoses inside the loop. Is that normal or did Dodge mash them in the bracket to make them fit?
Re: Heater hose bracket - 1968 Charger [Re: Lefty] #1245456
06/04/12 08:57 PM
06/04/12 08:57 PM
california
Mr D21 Offline
Mr D21  Offline
california
can't you just pry the bracket a bit more open ???
Re: Heater hose bracket - 1968 Charger [Re: Mr D21] #1245457
06/05/12 02:21 PM
06/05/12 02:21 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
They fit in tight... put the forward in first and follow with the other. You want them tight but not causing restriction.
The hole for the bracket and the holes for washer bottle are different sizes and in different locations. I believe the picture I posted is of a '66 or '67 b-body which is slightly different in that dept.
Re: Heater hose bracket - 1968 Charger [Re: 70mopes] #1245458
06/06/12 03:28 AM
06/06/12 03:28 AM
Los Altos Hills, CA
Dans 68 Offline
Dans 68  Offline
Los Altos Hills, CA
Here is a better shot of the installed bracket.
Dan
