Re: Braking question Dodge Ram
[Re: Kelob_pie]
#1245294
06/04/12 03:30 PM
06/04/12 03:30 PM
Posts: 6,516 Santa Cruz, California
Lefty
the driver side caliper retracts approx. a few thou, while the pass side retracts considerably more, about .040
That explains the pull as the right side pads are squeezing the rotor after the left side has already started squeezing.
I dunno, lots of possibilities - unequal piston friction in the calipers. unequal slider friction on the pads. Unequeal anti squeal goop on back of the pads. If you replaced both brake lines, look upstream at the hard lines and dist block. could be a kink or rust.
You could just keep throwing parts at it or buy a brake line pressure gauge and see if the pressure is equal on both sides before and after letting off the pedal.
[Re: Lefty]
#1245295
06/04/12 03:34 PM
06/04/12 03:34 PM
Posts: 3,897 Oregon
hooziewhatsit
It could also be a bad seal in the left caliper not allowing the piston to retract like it should. Since it sounds like most everything else has been checked, that would be the next thing I would look at. (how much is a rebuilt caliper?)
[Re: Kelob_pie]
#1245296
06/04/12 05:18 PM
06/04/12 05:18 PM
RapidRobert
put on a new/rebuilt passenger caliper
[Re: mopars4ever]
#1245301
06/05/12 09:49 AM
06/05/12 09:49 AM
Posts: 309 Hampden, Maine
Procommuter
super street
super street
Hampden, Maine
Could be a problem in the rear also.
Wes
73 Barracuda 440 EFI 4 speed, 144.85 MPH LTA A/FSS Record Holder.
