2003 Grand Caravan ES AWD with starting problem. #1245179
06/04/12 09:26 AM
06/04/12 09:26 AM
Montreal,Quebec,Canada
JulesdaWiperman Offline OP
super gas
super gas
Hi guys. Hope someone can help.
When I start the van I hear a fast ticking sound in the area of the radio/ heater control on the center dash console.
It ticks real fast then the engine just stops. To start the engine again I have to remove the key and start it again.
Sometimes the ticking starts again with the same engine result, sometimes it stops ticking and the engine runs fine.
Anyone know what is going on?
Jules
Re: 2003 Grand Caravan ES AWD with starting problem. [Re: JulesdaWiperman] #1245180
06/05/12 08:26 AM
06/05/12 08:26 AM
super gas
super gas
Re: 2003 Grand Caravan ES AWD with starting problem. [Re: JulesdaWiperman] #1245181
06/05/12 10:56 PM
06/05/12 10:56 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
what i would do is disconnect the battery to reboot the computers...
Re: 2003 Grand Caravan ES AWD with starting problem. [Re: AARCONV] #1245182
06/07/12 09:24 AM
06/07/12 09:24 AM
super gas
super gas
Did that with no change.
Next I am going to pull the radio and try to locate the sound more closely.
Jules
Re: 2003 Grand Caravan ES AWD with starting problem. [Re: JulesdaWiperman] #1245183
06/07/12 12:01 PM
06/07/12 12:01 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Sorry Jules. I don't remember if there was anything behind the center dash area that would be ticking or causing an engine shutdown
Best I can remember the only thing behind the radio is the heater box ??????
Re: 2003 Grand Caravan ES AWD with starting problem. [Re: gtx6970] #1245184
06/09/12 03:19 PM
06/09/12 03:19 PM
super gas
super gas
It's coming from the heater control unit.
I took the console panel off and started the motor.
The clicking comes straight from the heater module.
What I did so far is unplug the 2 plugs going to the module, checked the terminals
and plug them back on.
So far all works well again.
Thanks for the help.I am expecting more to come though.
Jules
