INDY OIL PUMP #1244906
06/03/12 07:09 PM
06/03/12 07:09 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
HELLO
on the indy oil pump on top ,there is a 1/4 tap pluged up
can you use this port as a pre lube port before you start the motor
or what is it for ?
I was thinking of putting oil in the line , running a #6 or #8 line to pre lube the motor
1.39 9.85 - 137 mph
Re: INDY OIL PUMP [Re: Ari440] #1244907
06/03/12 07:38 PM
06/03/12 07:38 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
That's a good place to plumb your accusump into.
Re: INDY OIL PUMP [Re: B G Racing] #1244908
06/03/12 09:22 PM
06/03/12 09:22 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Thats where my accumulator is plumbed in. works well for preluber also. Beep
Re: INDY OIL PUMP [Re: Bigbeep] #1244909
06/03/12 11:12 PM
06/03/12 11:12 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
That's where mine is as well. That port goes directly to the oil filter inlet.
Doug
Re: INDY OIL PUMP [Re: dvw] #1244910
06/04/12 01:45 PM
06/04/12 01:45 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
That is where my Master-Lube line is run to.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: INDY OIL PUMP [Re: MRMOPAR622] #1244911
06/04/12 09:31 PM
06/04/12 09:31 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
thanks guys
for now I will run a line up to the motor plate and cap it off
should I use #6 or #8 line
how much do the master lube / accu sump go for
any pics please
1.39 9.85 - 137 mph
Re: INDY OIL PUMP [Re: Ari440] #1244912
06/04/12 10:57 PM
06/04/12 10:57 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Ari>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://www.summitracing.com/parts/MOR-23900/
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: INDY OIL PUMP [Re: Ari440] #1244913
06/04/12 11:03 PM
06/04/12 11:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
thanks guys
any pics please
#8 minimum..........JMO
Re: INDY OIL PUMP [Re: Ari440] #1244914
06/05/12 12:48 AM
06/05/12 12:48 AM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
#8 is what I used.
