INDY OIL PUMP
#1244906
06/03/12 07:09 PM
06/03/12 07:09 PM
Posts: 5,618 long island NY
Ari440
long island NY
HELLO
on the indy oil pump on top ,there is a 1/4 tap pluged up
can you use this port as a pre lube port before you start the motor
or what is it for ?
I was thinking of putting oil in the line , running a #6 or #8 line to pre lube the motor
1.39 9.85 - 137 mph
Re: INDY OIL PUMP
[Re: dvw]
#1244910
06/04/12 01:45 PM
06/04/12 01:45 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
That is where my Master-Lube line is run to.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
Re: INDY OIL PUMP
[Re: MRMOPAR622]
#1244911
06/04/12 09:31 PM
06/04/12 09:31 PM
Ari440
long island NY
thanks guys
for now I will run a line up to the motor plate and cap it off
should I use #6 or #8 line
how much do the master lube / accu sump go for
any pics please
1.39 9.85 - 137 mph
Re: INDY OIL PUMP
[Re: Ari440]
#1244913
06/04/12 11:03 PM
06/04/12 11:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
thanks guys
any pics please
#8 minimum..........JMO
