1969 Charger Seam Sealer Locations Help Please
#1244662
06/03/12 11:19 AM
06/03/12 11:19 AM
Posts: 352 Arizona
69rrgrabber
Arizona
I'm ready to paint a 69 Charger that has been a 3 year project up to now, YES! So the previous owner had the whole car stripped and painted before I bought it and they took off alot of the sealer and didn't replace it all. The interior sealer was all there. I know about the rear corners and the rear valance corners, but I am not sure about the front firewall and also the sides of the firewall under the fenders.
Anyone have a guide or a picture reference?
Thanks, CAC
"It takes a Mopar to catch a Mopar!"
1969 Charger R/T 440
1969 Road Runner 383
1970 Cuda 440
Re: 1969 Charger Seam Sealer Locations Help Please
[Re: 69rrgrabber]
#1244663
06/04/12 03:30 PM
06/04/12 03:30 PM
Posts: 1,228 Maple Valley, WA
70mopes
Maple Valley, WA
Cowl to firewall and side panels (where mud shields screw in) were filled with a urethane seal and mated at the factory. it has a foamy consistency - Not the same material as seal you would find on your joints on floors, trunk, etc. which is shown in the factory shop manual. Excess of the urethane type stuff tended to spill out and set. That excess may get knocked off during blasting but the main part of the seal should still be in place. Regardless, Anywhere there is a joint, lap, butt splice whatever, seal it. Engine compartment does not have any seal other than firewall to cowl.
Post deleted by moparts
[Re: 69rrgrabber]
#1244664
06/09/12 10:51 AM
06/09/12 10:51 AM
#1244665
06/09/12 03:29 PM
06/09/12 03:29 PM
Posts: 352 Arizona
69rrgrabber
Arizona
What can I substitute for the foam sealer? Is seam sealer too thin? I do have some 3M Strip Calk, would that be good to use? Since these areas are hidden from view by the fenders they won't be seen.
I do know about the 4 drainage holes for the vents above the cowl so I will leave those open and fill everything. Who ever did the car last used bondo in places where the sealer or foam stuff should of gone, including in the lower door corner recesses, trunk and valance corners so I is a bit of a challenge figuring it out.
1970 Cuda 440
[Re: SeventySatellite]
#1244668
06/15/12 12:18 AM
06/15/12 12:18 AM
moparpollack
Lil Herman
Lil Herman
85086
No that stuff is for houses not cars. Talk to you local auto body supply store they will have the right stuff for the job. There are modern sealants that are designed not to hold water unlike the house stuff.
