Re: pick up coil [Re: earlybee] #124368
09/26/08 01:13 PM
09/26/08 01:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Looks too wide to me also. The reason we can tell is experience. You get an eye for that kind of thing when you do it often enough.
Re: pick up coil [Re: stumpy] #124369
09/26/08 04:35 PM
09/26/08 04:35 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Gotta measure all 8 paddles when there,s a missfire problem too. I,m guessing Don gets mad if people ask questions trying to help.
Re: pick up coil [Re: earlybee] #124370
09/26/08 07:22 PM
09/26/08 07:22 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
no i dont get mad cuz someone asked questions..
the reluctor is .008, but how-ever i did not check each one..
I will do that in a few and if they seem good then i will move the reluctor around to the other hole and see what happens..
Re: pick up coil [Re: Dakota_Don] #124371
09/26/08 07:49 PM
09/26/08 07:49 PM
It would be hard to tell from the pic if it's off as my brand new(1st ever ) digital camera does trick the eye like that without even trying. .008 is good. When a paddle is lined up square with the pickup magnet is the rotor pretty much under a dist cap terminal.
Re: pick up coil [Re: RapidRobert] #124372
09/26/08 09:48 PM
09/26/08 09:48 PM
Alton, IL
Alton, IL
well i give up lol..i have it running good with the original ign system (points) i tried everything and it has to be the PU coil.. I have a new (not rebuilt) dist coming.. so it will points for now.. thanks to all of you who tried to help and gave suggestions.
Re: pick up coil [Re: Dakota_Don] #124373
09/26/08 11:07 PM
09/26/08 11:07 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
I had electronic ignition on my shovelhead that gave me fits. Went back to points and never looked back. Still running them since 1979. Even though I know better,I still like the K.I.S.S. saying today.
