Poor performance #1243004
05/31/12 11:31 PM
05/31/12 11:31 PM
rpsrpsmopar Offline OP
My HEMI crate motor stalls in hot weather. Once it cools down it runs fine again then after several miles stalls again. What is my problem. Help appreciated.
Re: Poor performance [Re: rpsrpsmopar] #1243005
05/31/12 11:38 PM
05/31/12 11:38 PM
when it stalls hook your timing light up FAST & see if it's a spark or a fuel issue to start with
Re: Poor performance [Re: RapidRobert] #1243006
05/31/12 11:40 PM
05/31/12 11:40 PM
great suggestion thanks!
Re: Poor performance [Re: rpsrpsmopar] #1243007
06/01/12 12:02 AM
06/01/12 12:02 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
single carb? dual carb? Not that it really matters.. Maybe try an electric fuel pump.. or isolate the carb(s), mabey both.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Poor performance [Re: DARTH V8Я] #1243008
06/01/12 12:33 AM
06/01/12 12:33 AM
ALBERTA CANADA
CUDA8U Offline
CUDA8U  Offline
ALBERTA CANADA
do you have a high rise intake?
if you don't maybe when the engine is hot the fuel is vaporizing (boiling)causing it to stall
try a insulated spacer or high rise
just a guess
Re: Poor performance [Re: DARTH V8Я] #1243009
06/01/12 07:46 AM
06/01/12 07:46 AM
duel facttory origibal carbs. Ill try your idea about spacer thanks..
