Re: 10:1 Mild Stroker 416s - output?
[Re: AdamR]
#1243
04/28/04 11:20 PM
04/28/04 11:20 PM
Posts: 2,580 CT - just outside Hartford
Crazy73
just brining a great thread back from the dead.
Wow, I'll say! 08/06/03 11:07 PM
As of this point in time, I have neither the funds nor the time to go out and purchase parts for a stroker "moder" let alone put it together! I would also need to get subframe connectors, beef up the tranny, scrap the converter, etc. etc. Since I am moving (again) in the next 2 weeks, and only have a spot for one car, the Dart will have to remain elsewhere, and only be taken out once in a while.
It would be soooooooo nice, tho
Pete -1968 Barracuda 4spd 383-6pk
[Re: B3422W5]
#1244
04/29/04 07:11 AM
04/29/04 07:11 AM
Ok i am currently putting togther a 408 stroker ,Eagle H beams (needed very little clearancing )small notch in each opposing bore to clear rod bolt . (my Eagle rods are great all within .0007 of each other center to center length was all about 6.125).For any thing but an all out race motor i wouldnt wast my money on internal ballance (quoted $750 in Oz to get malory in mine )a quatity ballancer (360 type )and a B&M weighted flex plate then get this assembley balanced works for me( it will only see 6200 rpm ) .I agree with a cam choice of around 240 to 250 @50 (i will run an Engle hyd)10:1 comp single plane manifold and some ported heads . Will be a dream on the steet and strip . My 360 thati am still running is like above and runs 12s @ 109.1 mph in 68 Valiant.
#1245
08/26/04 01:20 AM
08/26/04 01:20 AM
#1246
08/26/04 01:39 AM
08/26/04 01:39 AM
Here's mine. Ryan ported my E-heads and I must say this sucker pulls strong through the whole rpm range. If this ever blows I will go with another stroker in a heartbeat. I haven't had it to the trackj yet but............ Desktop dyno claims 497hp through headers and full exhaust. Here's the specs on the engine: -360 block .030 or 4.030 bore X 4.00 stroke -Protru -20cc dish pistons, 10.7 to 1 -.039 head gasket thickness, -57cc head volume -Sixpack dual plane manifold port matched with a total of 1350 cfm's through the carbs -XE284H, Xtreme Energy, Hyd Flat Tappet, 284/296-240/246@50-.507/.510-110 centerline -Edelbrock Flow #'s .100"--79.4/58.7 .200"--151.8/118.7 .300"--212.2/168.4 .400"--254.6/200.8 .450"--269.1/212.1 .500"--276.0/219.8 .550"--280.1/221.8 .600"--281.6/225.6 .650"--282.9/225.6 .700"--284.7/225.6 2800-3200 stall speed convertor through a 727 3.91 suregrip 245/60/15 radials Here's some more stroker builds I saved from a post I had a while back. http://www.mopar1.us/stroker.html
#1247
08/26/04 09:28 AM
08/26/04 09:28 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
I built a stroker for great street manners and better torque
I was not much more expensive than a standard rebuild.,
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: Crazy73]
#1249
11/23/04 01:36 AM
11/23/04 01:36 AM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
BTT Can't be loosing this thread.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#1250
11/23/04 02:29 AM
11/23/04 02:29 AM
Posts: 6,293 Northeast, Alpine, NY
9 Sec Phill
On a road near you
On a road near you
I just got my 416 w2 stroker in my 69 fast back cuda this last fall. The motor was dyno pulled, 525 Hp , 510 lb ft. 9.47 comp, eagle H beam rods, Mopar steel crank, gear drive, comp cam, 280 @ 50.victor w2 intake, barry grant 850 . Hooker super comp headers. The motor pulls like no other small block I have ever had! The car is 3300 lbs.3.91 gear ,226x8.5 mt slick. I drive it to the local strip , takes me 45 min to get there. The best so far is a 7.58 in the 1/8 @ 91mph.1.64 60'. This was with a very loose converter. Could only foot brake to 2900. I just got a top of the line 8"dynamic converter built to the motors dyno specs. New welds to lighten up the car. If you like ,I can post the dyno sheets for all to see.As I said before, this is a pullin motor.As for street use , it would not bother me to drive this car to LA and back, other than the price of fuel. Hope this helps. Phill
[Re: 9 Sec Phill]
#1251
11/23/04 06:47 PM
11/23/04 06:47 PM
amxautox
Anyone have a link to where to buy a stroker crank? There was one for the Mopar stuff on the other thread about stroking, but that thread seems to be gone now. The link to the Mopar cranks and engine parts.
Tom
author unknown
[Re: amxautox]
#1252
11/23/04 10:31 PM
11/23/04 10:31 PM
Crazy73
Sweet mother! This thread is still alive, and I still have no 416 I guess there is too much $ going to beautifying my '68 Barracuda (read: rolling chassis resto) Looking through my archive of links here, I come to the following ideas: Call your local MP dealer The guys here in town quoted me 10% over cost (around 350 I think?) for one back in '03. Check the evil monster, aka eBay - good deals DO pop up.
