B&M Trans Cooler install Q? #1242821
05/31/12 03:08 PM
05/31/12 03:08 PM
Fly Over States
P
PHJ426 Offline OP
PHJ426  Offline OP
P
Fly Over States
Why would B&M suggest the trans cooler have the 1/2" inlet and outlets either be position the top or on the side but not on the bottom when installing the cooler in the car?
Any ideas on this?
Re: B&M Trans Cooler install Q? [Re: PHJ426] #1242822
05/31/12 03:31 PM
05/31/12 03:31 PM
NC
440Jim Offline
440Jim  Offline
NC
I am just guessing...
But maybe for elimination of air pockets in the plate type heat exchangers?
Re: B&M Trans Cooler install Q? [Re: 440Jim] #1242823
05/31/12 03:52 PM
05/31/12 03:52 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Re: B&M Trans Cooler install Q? [Re: jamesc] #1242824
05/31/12 04:06 PM
05/31/12 04:06 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I guess I should have read the directions! Mine are on the bottom. I havent had any problems yet!
67' charger 499 RB 10.57 at 127
Re: B&M Trans Cooler install Q? [Re: 440Jim] #1242825
05/31/12 04:49 PM
05/31/12 04:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah just a air issue
Re: B&M Trans Cooler install Q? [Re: MR_P_BODY] #1242826
05/31/12 05:14 PM
05/31/12 05:14 PM
Renton Washington
Triple Threat Offline
Renton Washington
Mine have been installed on the bottom since the car was built 7 years ago. No ill effects.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: B&M Trans Cooler install Q? [Re: MR_P_BODY] #1242827
05/31/12 05:19 PM
05/31/12 05:19 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i agree on the air lock issue as i think this was my problem for a season or two til i swapped my hoses around. on some runs the temp on the trans would be high 220+ & other runs later in the day it would be lower 180ish. i had inadvertedly plumbed it in the bottom & out the top, so i changed it around to the opposite & now it stays the same, always under 200*.
Re: B&M Trans Cooler install Q? [Re: Triple Threat] #1242828
05/31/12 05:46 PM
05/31/12 05:46 PM
Fly Over States
P
PHJ426 Offline OP
PHJ426  Offline OP
P
Fly Over States
l didn't open up the directions until I was done either. For now the inlet and outlet are both at the bottom. I would think the hydraulic system in the trand isn't there a vent in the trans?
Re: B&M Trans Cooler install Q? [Re: PHJ426] #1242829
05/31/12 09:38 PM
05/31/12 09:38 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Gotta love the honesty on not reading directions. Think we all been there done that!
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: B&M Trans Cooler install Q? [Re: B Dartman] #1242830
05/31/12 11:38 PM
05/31/12 11:38 PM
Fly Over States
P
PHJ426 Offline OP
PHJ426  Offline OP
P
Fly Over States
And the way I mounted it lent itself to either pointing the 1/2" pipe inlet / outlet either to the both up or both down positions.
I had a 50 /50 shot at it...........
Re: B&M Trans Cooler install Q? [Re: PHJ426] #1242831
05/31/12 11:59 PM
05/31/12 11:59 PM
jamesc Offline
jamesc  Offline
man this is just TOO funny cause i've been right there losing that 50-50 shot, these days i look at the directions for a hammer.
it's really bad when you open a box with the most basic piece that you think wouldn't even have directions with it so you toss them only to find out you installed it wrong when you could have handed it to ANYONE and they had 50-50 chance of getting it right
sorry you got it wrong but it did make me smile knowing i wasn't alone
