Weighing Car? #1242785
05/31/12 12:33 PM
05/31/12 12:33 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Do people actually weigh their cars before buying performance suspension parts? I have digital scales but don't know how I will use them. Tim
Re: Weighing Car? [Re: astjp2] #1242786
05/31/12 12:41 PM
05/31/12 12:41 PM
AndyF Offline
AndyF  Offline
I do. I weigh the car all the time and keep track of the weight distribution when making modifications.
Re: Weighing Car? [Re: AndyF] #1242787
05/31/12 12:44 PM
05/31/12 12:44 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
I always scale the car prior to events with me in it and a fuel load so I can get the corner weights just right.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: Weighing Car? [Re: Viol8r] #1242788
05/31/12 01:30 PM
05/31/12 01:30 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I have digital scale weights for my car before my second round of suspension mods and before my motor mods.
But I don't own a set of scales, so I can't do constant measurements.
Re: Weighing Car? [Re: astjp2] #1242789
05/31/12 04:49 PM
05/31/12 04:49 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Most, heck, nearly all, do not. This is why suspension set ups have been looked at like voodoo for so long. Most of what most people do is a simple guess or based on what someone else has that seems to work.
Ideally I like to, but I can't always get things on a four wheel scale with any regularity. I'll at least do a front/back check at the local drywall place since they have a scale. To me, that is the minimum starting point to understand where your at and where you need to go.
Redistributing weight and lightening things up are always nice and desireable goals, but you can make a seemingly heavy pig perform well if you know your starting point.
Re: Weighing Car? [Re: TC@HP2] #1242790
05/31/12 05:25 PM
05/31/12 05:25 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
To me it is one of the more important things if you are running the car in different conditions. If you are making adjustments and not doing this off of a baseline that is accurate, how do you keep proper notes? I guess its the old stock car racer in me.
Re: Weighing Car? [Re: Viol8r] #1242791
05/31/12 10:34 PM
05/31/12 10:34 PM
IN
ahy Offline
ahy  Offline
IN
I scaled mine (front/rear only) at the local aggregate supplier. 4 wheel would be nice but not readily available. Its a reference and baseline for improvement. In my case, 54/46 weight distribution isn't bad, but now that I know I want to get to 50/50. Need to loose some weight in the front.
Re: Weighing Car? [Re: ahy] #1242792
06/01/12 03:23 AM
06/01/12 03:23 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
this was done on Hotchkis' digital scales without driver before Hotchkis TVS and 1.12" T-bars were added (from .99" T-bars) . Just a baseline and for ride height measurement changes.
Car at this measurement compared to what I have now:
Before (pics below) / Now
  • Cast iron head/Edelbrock aluminum heads
  • Cast iron 4bbl intake/MP M1 intake
  • Cast iron 340 HP exhaust manifolds/TTI 1 3/4" step headers
  • Cast iron water pump/aluminum water pump
  • OE type alternator/Denso 102mm mini alternator
  • OE type brass radiator/4 core aluminum Champion radiator
  • Two OE Hi-Lo horn/One plastic aftermarket horn
  • No trans cooler/HD 11"x5.5" trans cooler
  • Modified stock type suspenion with .99" T-bar/Full Hotchkis TVS with 1.12" T-bars
Re: Weighing Car? [Re: autoxcuda] #1242793
06/01/12 05:34 AM
06/01/12 05:34 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Curious...
I've always had my cars weighed at the local dump. You drive in, weigh the car, dump your crap, drive out, weigh again and they calculate the difference and charge you. Mine let me just drive in, weigh the car and leave, and from my own experience, they are pretty accurate. Same type as you find at the track.
I was wondering, now that i'm aware ov my awful weight bias and trying to fix it, would just driving the front wheels onto the scale, getting a reading, then backing the rear wheels (in the same place) and getting a reading work for accurately measuring bias? I'm sure if there was no traffic my scales would let me do that. If i were to get as much ov the car onto the scale (wheels closest to the middle) as possible... then repeat on the rear, would that be worth anything? Perhaps not to accurately add up to a whole, but maybe just to ballpark my bias? I'm pretty sure my scale wouldn't even charge me to do that.... i'd just get the usual funny looks...
Re: Weighing Car? [Re: Pale_Roader] #1242794
06/01/12 07:40 AM
06/01/12 07:40 AM
IN
ahy Offline
ahy  Offline
IN
Some - not all - truck scales are accurate for absolute weight. I just ask. The one I use is calibrated for +/-20 lbs absolute weight which is close enough. I weigh 3 times: whole car, front, rear. The whole car weight is a check. For the split weights, approach the scale from the same side each time so any effect of uneven ground is at least consistant.
Re: Weighing Car? [Re: ahy] #1242795
06/01/12 04:28 PM
06/01/12 04:28 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Well I have a set of scales, if anyone is in the Salt Lake City area and wants to weight their car, I am willing to do it...Tim
1500# per pad.....
Re: Weighing Car? [Re: astjp2] #1242796
06/02/12 08:33 AM
06/02/12 08:33 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Yes and no.
If this is a competition car, even part time, you will be constantly improving and tuning it. Corner weights are very useful. For someone simply upgrading to a sporty suspension for general use, probably not. Simply copy an established package, and unless that is not satisfactory, weights are interesting to share but not going to be needed.
When I first bought the car, I did not weigh it. Frankly, although I wanted to, in retrospect it wouldn't have been that helpful. It was a tired /6 car being switched to v-8; springs, shocks, rear axle all were being swapped. So there was no baseline to work from. I did use the Brookland Book's magazine reprints to get an idea of what the stock v-8 and notchbacks balanced at.
That said, after it was together, I scaled the car whenever opportunity arose. At the dragstrip at first (total weight). Later at shops that had scales, and that's where I could do front-back.
Now when is most useful? First when deciding on changes. Besides weighing the car, you can use the scales to check leaf spring rate. Weigh the car as it will be used. Load up the driver's area with weight if you can't be sitting in it. Set the ride hieght where you want it. Some people will adjust the t- bars to equalize the corner weights, others may prioritize equalizing right-left ride heights. Whichever, make sure the sway bars are not pre-loaded (unless you want that for some reason).
Re: Weighing Car? [Re: Pale_Roader] #1242797
06/03/12 11:10 AM
06/03/12 11:10 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
That's what I do most the time. Its a decent start and better than nothing.
Re: Weighing Car? [Re: TC@HP2] #1242798
06/04/12 08:23 AM
06/04/12 08:23 AM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Thats about all i can ask for... I can get a good deal on having the car scaled (as i just did), but for this gutter-budget i think that will be about the last time. Ballparkin' it can go a long way...
Re: Weighing Car? [Re: Pale_Roader] #1242799
06/05/12 08:25 AM
06/05/12 08:25 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
The other item scales can be used for is to take measurements that can be used to calculate the location of the center of gravity. Puhn's book eplains this and the example is done on truck scales.
Re: Weighing Car? [Re: Mattax] #1242800
06/08/12 01:50 AM
06/08/12 01:50 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
If you pick a datum point, measure each weigh point distance which equals the arm
weight X arm = moment
all moments / total weight = CG
