Re: Anyone know about Demon carbs?
[Re: daytona5812]
#1242482
05/31/12 02:22 AM
05/31/12 02:22 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Vern are you saying it will not get up on the chip to launch on the brake? Or it gets on the chip fine but when you let go of the button it stumbles?
[Re: daytona5812]
#1242488
05/31/12 08:19 PM
05/31/12 08:19 PM
Al_Alguire
Las Vegas
Does it have the correct floats? Meaning for a sideways mounted carb. I assume so but had to ask. Assuming this is a TS car leaving hard. I cannot imagine it is a lack of fuel at that point unless the floats are way off so will assume it is to much?!?
We haev a king Deomon on the brand X car and never really had any issues with it ever. Actually runs like a champ and always has.
Maybe it's puking out the vents? Maybe tie them together with a piece of fuel hose or plug boots and hose. Or possible the floats are a tad high..
At any rate good luck with it. We will be running next weekend up on the hill here. Go get em..
[Re: Al_Alguire]
#1242489
05/31/12 09:08 PM
05/31/12 09:08 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Is the acc pump starting to squirt the moment the throttle moves? if not, On my Demon there's a metal linkage that goes from the primary throttle shaft and operates the acc. pump, It needed to be bent to eliminate a hesitation I had in the acc pump squirt. In short it wasn't squirting soon enough, and bending this linkage eliminated the delay.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
