Reinforcing plate and adjustable leaf spring hanger Q? #1242164
05/30/12 02:12 PM
05/30/12 02:12 PM
Fly Over States
P
PHJ426 Offline OP
PHJ426  Offline OP
P
Fly Over States
Installing the Firm Feel adjustable (2 position) front leaf spring hanger and reinforcement plate on a 72 B body.
When using both of these together is it necessary to install longer studs into the front hanger?
I want full nut engagement to the stud as to maximize the clamping force. What is your experience with these 2 products used together?
Re: Reinforcing plate and adjustable leaf spring hanger Q? [Re: PHJ426] #1242165
05/30/12 03:33 PM
05/30/12 03:33 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
I'm using the hangers without the plates and I have about 1/4" of the stud sticking out with the nuts tightened if that helps.
Re: Reinforcing plate and adjustable leaf spring hanger Q? [Re: PHJ426] #1242166
05/30/12 03:36 PM
05/30/12 03:36 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
No first hand experience with those two pieces, but the rule of thumb for thread engagement is you want at least the width of the stud to protrude through the nut as length. Skip using lock washers and use a chemical bonder like Loctite if you want an extra measure of confidence.
Re: Reinforcing plate and adjustable leaf spring hanger Q? [Re: PHJ426] #1242167
05/30/12 05:52 PM
05/30/12 05:52 PM
AndyF Offline
AndyF  Offline
There should be plenty of thread length to go thru the chassis as well as the plate.
The chassis sheet metal isn't very thick in the hanger box which is why the plates are a good idea. The factory nuts have an integral washer so they are taller than a simple hex nut, but there should still be plenty of thread for everything to fit.
The important thing is to put the reinforcement plates on the inside of the chassis so they actually reinforce the area. I've seen people put them under the spring hanger and then they are just a spacer. The only reason to put them under the hanger is to adjust the axle thrust angle.
Re: Reinforcing plate and adjustable leaf spring hanger Q? [Re: AndyF] #1242168
05/30/12 08:12 PM
05/30/12 08:12 PM
Fly Over States
P
PHJ426 Offline OP
PHJ426  Offline OP
P
Fly Over States
Thanks the reply Andy.
Check I have the plate inside the torque box area not behind the hanger.
For some reason I was thinking there was more thread to get into the factory encapsulated washer and nut. But that was late last night after I had finished hanging everything.
Now that I have another look at it there is full engagement of the threads and a little more sticking out of the nut.
I think what got me more messed up is the local spring shop set me up with U bolts for the axle that are 19MM. The 3/4 Impact socket was just a tad too small for them.
Sorry about that...
Re: Reinforcing plate and adjustable leaf spring hanger Q? [Re: AndyF] #1242169
05/30/12 08:13 PM
05/30/12 08:13 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Both the Army and Air Force spec. out 1-3 threads sticking through the nut, any more and its just extra weight.
Re: Reinforcing plate and adjustable leaf spring hanger Q? [Re: astjp2] #1242170
05/30/12 10:45 PM
05/30/12 10:45 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I like the way you think, lightweight is where it's at!
Re: Reinforcing plate and adjustable leaf spring hanger Q? [Re: Challenger 1] #1242171
05/30/12 11:54 PM
05/30/12 11:54 PM
Fly Over States
P
PHJ426 Offline OP
PHJ426  Offline OP
P
Fly Over States
I think we are in spec then
Re: Reinforcing plate and adjustable leaf spring hanger Q? [Re: astjp2] #1242172
05/31/12 10:22 PM
05/31/12 10:22 PM
Jacksonville Fl
70BigBlockSE Offline
Jacksonville Fl
Navy is the same way, contractors are penalized if too many threads are exposed.
