Big bolt pattern Drums for a A Body with stock brakes #1241951
05/29/12 11:24 PM
05/29/12 11:24 PM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
Anyone have a part # for a drum that will work on a A body with the 1 3/4 wide brakes with big bolt pattern 5 on 4 1/2
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: Mpetros] #1241952
05/29/12 11:29 PM
05/29/12 11:29 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
No such an animal, you need to drill the new bolt pattern in your drums, been done for 40 years... I usually use 11" brakes from a C-Body.
JB Rhinehart, Realist
A-Body's RULE!
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: Rhinodart] #1241953
05/29/12 11:38 PM
05/29/12 11:38 PM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
Someone told Me that a 65 or 66 B Body with a 6 Cyl and a 7 1/4 Rear has the big bolt pattern and the 1 3/4 wide brakes
looking it up they show 1 3/4 wide brake shoes but no drum pt#
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: Mpetros] #1241954
05/29/12 11:43 PM
05/29/12 11:43 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Moser used to drill axles and drums for about $100.
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: Mpetros] #1241955
05/30/12 01:13 AM
05/30/12 01:13 AM
AndyF Offline
AndyF  Offline
You can put B-body or E-body drum brakes on an A-body. Just need to change the upper control arm if the car is 1972 or older.
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: Mpetros] #1241956
05/30/12 06:26 AM
05/30/12 06:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes that is the application for the drum ... up to 70 ... good luck finding it. The last time I saw them the seller wanted $300 EACH. If you try to put these on redrilled stock axles you will have to make a spacer ring for the center hub.
I'd like to have a pair of them myself .
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: JohnRR] #1241957
05/30/12 08:30 AM
05/30/12 08:30 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Why dont you want BBP discs ?
I am truckless..
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: Mpetros] #1241958
05/30/12 08:39 AM
05/30/12 08:39 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
Pretty sure you are talking about rear drums...right?
It takes gasoline to interest me.
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: VL21] #1241959
05/30/12 09:45 AM
05/30/12 09:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes he is asking about rear drums .
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: JohnRR] #1241960
05/30/12 10:45 AM
05/30/12 10:45 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I had heard of the B-Body drums, but in 34 years of working on Darts I too have never seen a set and I have converted dozens of rear brakes.
A-Body's RULE!
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: Rhinodart] #1241961
05/30/12 12:11 PM
05/30/12 12:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I actually owned a car that would have had them ... 68 coronet 4 door with a /6, pretty sure it had a 7.25 rear in it, parted it almost 20 years ago ....
I'm going to make a call, I may be able to get my hands on one.
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: JohnRR] #1241962
05/30/12 12:12 PM
05/30/12 12:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Called my source , I may have one in my hot little hands next week .
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: Mpetros] #1241963
05/30/12 01:03 PM
05/30/12 01:03 PM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
any competant machine shop can do it. check around your area.
i had mine done 10yrs.ago by moser.
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: JohnRR] #1241964
05/30/12 02:30 PM
05/30/12 02:30 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
So the drums on these cars are worth some coin. Next time I'll keep this in mind before I sell them for a penny a pound.
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: Mpetros] #1241965
05/30/12 03:30 PM
05/30/12 03:30 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
No one has asked, so I will.
Are the axles the stock a body ones that have been re-drilled to the big pattern?
Or are they cut down big car ones, or aftermarket?
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: moparpollack] #1241966
05/30/12 03:38 PM
05/30/12 03:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Pretty much, I didn't even know this drum existed till this question came up within the last year and I looked in my factory parts manual.
I'm either reading into the OPs question too much or some are missing the point.
Here is how I see the question being asked ....
I am buying larger bolt patten AFTERMARKET axles to REPLACE the stock small bolt pattern axles . I have to keep the original factory track width because my tires are too close to my quarter panels using stock factory steel wheels ... which I have to run for the class I race in ... this means I must keep my stock axle offset and 1.75 wide brake shoes because I am using HUBCENTRIC rims.
If I drill out my stock axles and brake drums then I need to make a spacer to run hubcentric wheels, but I'm going to be running a spool and I have to use green bearings I have to switch to an aftermarket axle to be SAFE on the track.
Is there a drum that will fit the factory A body axle hub offset and works wit hthe stock A body brakes ?
The answer is YES ...
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: VL21] #1241967
05/30/12 03:39 PM
05/30/12 03:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Valid question that we all seem to be ASSuMEing the answer in order to TELL the OP what to do .
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: VL21] #1241968
05/30/12 10:19 PM
05/30/12 10:19 PM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
The Axles are Moser,
Ok heres the Story, A local Guy walks in My Shop with a pair of A body small bolt Stock axles. He wanted to buy big bolt pattern Axles.
I then asked what brakes are you going to use your stock or B Body.
He replied I like to use My stock brakes, so I ordered from Moser A body length axles with big bolt pattern.
So He called me the other day and said he cant find a drum to fit, so I then said I can redrill your stock drums to 5 on 4 1/2.
He said he didnt want to do that because it would weaken it.I explained that the rim is clamping the drum to the Axle, even with 5 extra holes it would still be safe.
I then said Ive sold Hundreds of Axles with Dual patterns for racing and on the street. Still I could not convince him to redrill his drums..
So I told him I would look into finding something that might work.
any help would be appreciated
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: Mpetros] #1241969
05/30/12 11:24 PM
05/30/12 11:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do the axles have the big bolt pattern center register or the small bolt pattern center register ? Do the axles with the B/E offset or the A offset ?
Re: Big bolt pattern Drums for a A Body with stock brakes [Re: JohnRR] #1241970
05/30/12 11:38 PM
05/30/12 11:38 PM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
The New Moser Axles are Identical Hub register and length and brake gap as the stock A body with small brakes..
Yes Moser uses a different length and Hub register if you are going use B Body Brakes
