Re: Fast flowed my Chapmans today!
[Re: JohnRR]
#12518
08/05/04 08:26 PM
08/05/04 08:26 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
John,
I thought the original B1 would (or could be made to)work.
I'm really leaning toward a 440-25 but I can't find any data on it. With these ports and 2-4's I think there could be big gains worth going after upstairs. Besides, I never really had a multi-carb street car!
[Re: Streetwize]
#12519
08/06/04 11:22 PM
08/06/04 11:22 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
Bobby, I've got a Eddy TM7 that has been nicely modified to accomodate Max Wedge ports. I have it sized for raised port B/RB heads. There is alot of material above the port that can still be removed. I also increased the runner size on a couple ports, but the work came to a standstill when I found a Wieand dual quad and a heavily modified tunnel ram to suit my heads. If you want some pics, let me know. I'm taking it to a swap meet Saturday with some other stuff I don't plan on using. It likely won't sell in unfinished condition.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: racealittle]
#12520
08/07/04 09:23 AM
08/07/04 09:23 AM
Streetwize
Weddington, N.C.
Phil, Hey, thanks buddy! I'm still a good bit away from getting anywhere near assembly, I actually have a project ahead of the 517 that needs to be finished and the starter just went out on the Charger (defective bendix, I guess) I'm leaning toward multiple carbs on this thing and that INDY rat roaster looks pretty cool, wish I could find more 'real' info about it.
[Re: Streetwize]
#12522
08/09/04 10:37 AM
08/09/04 10:37 AM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
i'll see what needs to be done , what i need is a post with the numbers you want added so i can give them to tom ...
[Re: JohnRR]
#12523
08/09/04 11:04 AM
08/09/04 11:04 AM
Streetwize
Weddington, N.C.
Like This?
Lift" I/E
.100 72.5/58.2
.200 153.7/118.6
.300 224.3/178.2
.400 285.2/218.2
.500 329.6/232.8
.600 361.9/245.1
.650 368.1/249.9
.700 364/253.1
.750 364/254.7
.800 364/256.3
Thanks!
So where's your 260 #'s? Did Dwayne have 11/32 valves? I'll bet he does, that's standard Indy size too IIRC
[Re: Streetwize]
#12524
08/09/04 12:46 PM
08/09/04 12:46 PM
JohnRR
U.S.S.A.
indy size is 2.20 at 5.4 ??
haven't sent them up , he never responded if he had the valve when i asked in the post , probably didn't see it ...
[Re: JohnRR]
#12525
08/09/04 12:50 PM
08/09/04 12:50 PM
Streetwize
Weddington, N.C.
Oh, is it 2.200"? My bad, thought it was 2.19". He can use the indy length or BBC for flow 'checking springs', pretty sure that's what he did with mine. We know he has the exhaust valve
[Re: Streetwize]
#12526
08/09/04 01:06 PM
08/09/04 01:06 PM
JohnRR
U.S.S.A.
what did you end up doing for valves ??
[Re: JohnRR]
#12527
08/09/04 01:59 PM
08/09/04 01:59 PM
Streetwize
Weddington, N.C.
Ain't got 'em yet, heck I still only "Have" one head! I'll wait till Dwayne sends me the other one, probably get a set of Fereas custom cut. I think Chuck had a good Idea....get all the rocker gear first, check/verify all the geometry (I have some 11/32 "dummy" valves...no 2.200" though, sorry! ), then order the valves. Makes sense to me
[Re: Streetwize]
#12528
08/09/04 02:24 PM
08/09/04 02:24 PM
JohnRR
U.S.S.A.
i was wondering , i was thinking of goingthe custom route also .
funny , i only have one head also ...
[Re: Streetwize]
#12530
08/10/04 08:22 PM
08/10/04 08:22 PM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
i might have a 2.20 valve laying around. if not, i'd just get a budget 2.25 BBC valve and cut it down.
[Re: JohnRR]
#12532
08/17/04 11:08 AM
08/17/04 11:08 AM
Streetwize
Weddington, N.C.
John, Did you send Dwayne the 260's yet? Got mine back from Dwayne on Friday, now the fun begins and the wallet drains Billet caps will be on the dance card!!
[Re: Streetwize]
#12533
08/17/04 11:26 AM
08/17/04 11:26 AM
JohnRR
U.S.S.A.
no , i forgot to bring them over to my dad before i went to the nats , i'm going to run them over tonight for him to drop off tomorrow ...
[Re: JohnRR]
#12534
08/19/04 09:15 PM
08/19/04 09:15 PM
JohnRR
U.S.S.A.
heres dwaynes numbers vs what chapman advertises for the 260cc head
chapman
Flow Figures @ 28"
Intake Exhaust
.100 71 55
.200 157 112
.300 230 177
.400 290 211
.500 325 233
.600 351 242
.700 351 252
PRH
lift---in/ex
.100--71.5/58.2
.200-150.0/118.6
.300-219.4/180.0
.400-278.7/219.4
.500-323.6/233.9
.550-338.9/240.3
.600-352.3/243.5
.650-348.5/246.7
.700-348.5/249.9
.750-348.5/251.5
.800-348.5/253.1
they might get my car deep into the 12's
[Re: fast68plymouth]
#12536
08/19/04 10:10 PM
08/19/04 10:10 PM
Posts: 1,361 Wild West
M_D
Wild West
Those numbers look comparable to the E.M. heads, except they are stronger in the mid-lifts. It would be interesting to have side by side numbers with the same bore adapter.
