69 Hemi is breaking up at 3200 rpm. Its Fixed!!!!
#1241671
05/29/12 10:59 AM
05/29/12 10:59 AM
Posts: 579 Wattsburg, Pa
Dr V
Wattsburg, Pa
Well, I have the hemi back in my 69 black RR. Custom 3000 stall, motor is 40 over with orig manifolds, mild cam, brand new restored orig carbs, new firecore wires, mopar electronic ign, electric and mech fuel pump with 10 psi at idle and 6 psi under full throttle. Car idles wonderful and rips the tires off from the line but it seems to break up (seems electrical) at about 3200 rpms when the pedal is to the floor. Seems to choke and it wont pull hard all the way. Im at my wits end.
69 1/2 A12 BEE 4 spd 1968 Charger 383 1970 Roadrunner 440+6 Survivor 2019 Redeye 2005 FORD GT Red/White 2017 Viper ACR Extreme Red/White 1979 Branco Red/Red 2018 Porsche GT3 Miami 1971 440+6 Cuda 4 speed V2 2020 Sebring Orange Vette 1979 Chevy Boogie Hippie Van
Re: 69 Hemi is breaking up at 3200 rpm. Help!
[Re: Dr V]
#1241672
05/29/12 11:06 AM
05/29/12 11:06 AM
Challenger 1
Cincinnati, Ohio
My I have installed 3 brand new MP distributers right out of the box. All 3 would breakup under load, I ohmed the pickups and all three were different than stock pickups that I had laying around. So I installed used pick ups in all 3 distributers and the breaking up went away. 3 times I experienced this with MP distributers and all 3 times replacement pickup fixed the problem.
[Re: Dr V]
#1241673
05/29/12 11:10 AM
05/29/12 11:10 AM
Dr V
Wattsburg, Pa
Ya know, I am leaning towrds the distributor too, Its the only thing that I havent replaced. Literally!! I changed the box from orange to chrome, no change. Do I just order a new one from mancini or summit? Whats best??
[Re: Challenger 1]
#1241675
05/29/12 11:29 AM
05/29/12 11:29 AM
RapidRobert
try disconnecting the vac advance & see if that makes it better or worse. rotor phasing.
[Re: Challenger 1]
#1241676
05/29/12 11:48 AM
05/29/12 11:48 AM
Dr V
Wattsburg, Pa
All I have at home is an original points dist that came out of my 68 charger 383.
[Re: RapidRobert]
#1241677
05/29/12 12:00 PM
05/29/12 12:00 PM
Dr V
Wattsburg, Pa
RapidRobert, I run the car with it plugged.
[Re: 67Satty]
#1241685
05/29/12 02:29 PM
05/29/12 02:29 PM
Dr V
Wattsburg, Pa
So the gap for each fin should be .008???? Thanks, I will look at that tonight after golf league, If im not seeing straight then tmrw afternoon it is!! Thanks..
[Re: Dr V]
#1241686
05/29/12 03:38 PM
05/29/12 03:38 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
Yeah, .008. But it's not super critical. It will run fine if it's anywhere close to that. But if it's too wide a gap, like really wide, you will sputter at higher RPMS under load. But set it at it's tightest point. That way you won't be shaving plastic because the distributors, even the new ones don't have perfect runout. Here's a good thread: https://board.moparts.org/ubbthreads/showflat.php?Number=5393292
[Re: RapidRobert]
#1241688
05/29/12 04:25 PM
05/29/12 04:25 PM
Dr V
Wattsburg, Pa
I will check that gap for sure. What would make it go out of wack? Bad bushing in the shaft or something?
[Re: Dr V]
#1241689
05/29/12 04:52 PM
05/29/12 04:52 PM
RapidRobert
locking screw loose or gap set incorrectly in the beginning
[Re: RapidRobert]
#1241690
05/29/12 05:03 PM
05/29/12 05:03 PM
Challenger 1
Cincinnati, Ohio
I don'tt think they are setup when new, all 3 I did needed the gap set and I'm sure some screws were loose. I think they figure your going to set it up for your engine, there adjustable. Not ready to drop in and run.
