Southern Ontario torque converter ?
#1241641
05/29/12 10:32 AM
05/29/12 10:32 AM
Posts: 670 Third rock from the sun.
busboy
Who builds a good torque converter in Southern Ontario? My 340 has a shake that starts at idle and never gets any better. We've ruled out any ignition stuff, so we're thinking converter. The whole set up was purchased used, I was told it was a 2800 stall. Any suggestions?
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Southern Ontario torque converter ?
[Re: 1962Savoy]
#1241643
05/29/12 01:19 PM
05/29/12 01:19 PM
busboy
Thanks Savoy, he's got a good website but I'm up in Barrie, London's a bit out of my way. Anybody know of anyone in the Toronto area?
[Re: Dodgem]
#1241645
05/29/12 04:20 PM
05/29/12 04:20 PM
Posts: 579 Wattsburg, Pa
Dr V
Wattsburg, Pa
Brian at BDR built a nice one for my hemi car. He builds them for Warren Johnson and those funny car guys. He's in Buffalo. http://stores.bdrtorqueconverters.com/StoreFront.bok
69 1/2 A12 BEE 4 spd 1968 Charger 383 1970 Roadrunner 440+6 Survivor 2019 Redeye 2005 FORD GT Red/White 2017 Viper ACR Extreme Red/White 1979 Branco Red/Red 2018 Porsche GT3 Miami 1971 440+6 Cuda 4 speed V2 2020 Sebring Orange Vette 1979 Chevy Boogie Hippie Van
[Re: Dodgem]
#1241646
05/30/12 12:58 AM
05/30/12 12:58 AM
busboy
Funny you mention that Dodgem, there is a weight on the converter. It's a 1969 motor, so internally balanced. The tranny comes out this weekend, try and get to the bottom of this. Any thoughts on a B&M Holeshot 3000 stall converter?
[Re: busboy]
#1241647
05/30/12 10:53 AM
05/30/12 10:53 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
get under there and chizel that weight off you will be amazed! M&M should be fine. Pats 3000's from SMR work good too!
[Re: 666]
#1241649
05/30/12 02:10 PM
05/30/12 02:10 PM
busboy
Great suggestion guys, I'm gonna knock that weight off and see what I've got. Not sure about the flex plate now, how would I tell the difference?
[Re: Dodgem]
#1241650
05/30/12 02:12 PM
05/30/12 02:12 PM
busboy
Dodgem, I've talked with Pat at SMR, good guy and very knowledgeable just a little spendy for my snack bracket
[Re: busboy]
#1241653
06/07/12 01:17 AM
06/07/12 01:17 AM
busboy
Update, no weight on the converter, so tranny came out, installed a B&M Holeshot, also no weight on that one. Their description http://bmracing.com/?wpsc-product=chrysl...orqueflite-a-72 doesn't mention cast vs forged crank or internal vs external balancing. Motor still has a shake, but it's a bit better. My local old school transmission shop looked up a converter for my motor (1969 340), his book shows only one, with 2 weights, for a cast crank motor, he thinks I put in the wrong converter What's the deal, did 69' motors use cast cranks? and do I need a converter with weights or not?
[Re: busboy]
#1241654
06/07/12 02:16 AM
06/07/12 02:16 AM
Posts: 37 Canada's West Coast
Graham
Canada's West Coast
There are two types of cranks in a Chrysler from the factory, a cast crank and a steel crank. Determine which crank your engine has, and order the matching converter. I don't care whose converter you buy or where you buy it from, but one of the first questions you should be asked by your supplier: is it a cast or steel crank. If they don't ask you that question, run don't walk from that supplier, as they don't know squat (unless it's a Chebbie) about converters. I've dealt with Pat at SMR in the past, and he has a wealth of knowledge on Mopars, he will make sure you get the proper converter for your application. There are 4 common mounting (flex) plates from Chrysler. 2 for the 11" converter and 2 for the 12" converters that they used. They also have two different bolt patterns to mount the plate to the crank, so make sure you check that out before changing the mounting plate for the converter. If you want, I can get you more accurate information tommorrow. Also, are you sure you want 2800 RPM stall? A high stall converter properly applied is a great addition but an impoperly applied high stall is one of the worst performance investments you can make. Graham
[Re: brads70]
#1241657
06/07/12 12:20 PM
06/07/12 12:20 PM
busboy
Yup, I'm in Barrie, think I saw your car last night down by the lake. Nice ride I haven't been out this year yet, want to get these gremlins sorted out.
[Re: busboy]
#1241659
06/10/12 11:58 AM
06/10/12 11:58 AM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
If it has a an external balance damper on it don't be surprised if you find out that you have bought a cast crank 340 or 360 even. This may come as a shock but sellers have been known to enhance the truth a little to make a sale. '69 340 is one of those buzzwords that seem to wind up in A-body ads 'cause everybody knows 69 was the good one. Just like ads for 440 HP blocks that ask a premium for the HP when in fact there is no difference between a non HP and an HP. The only way to properly diagnose this IMHO is to confirm whether it has a cast or forged crank, so the pan needs to come off. If it has a cast crank, B+M makes a flexplate that is balanced so you can use a neutral balance converter like you have. If it has a steel crank just get a neutral balance front damper and you should be golden but you need to confirm which crank it has. If you change the damper and it has a cast crank it will just shake harder. Kevin
[Re: Twostick]
#1241660
06/17/12 10:09 PM
06/17/12 10:09 PM
busboy
Thanks Twostick, block says 340-6 so I think I'm ok, but I know what your saying! Here's the update, pulled the damper, casting number starts with a 40 which I think is for late 70' 360, it's the one that came on it Pulled the damper of my 70' steel crank 318, local Mopar scrap yard says same part number for 69' 340, cleaned it up, a splash of paint, on it went, motor is now smooooooth thanks to all for your help.
