Re: is 650cfm enough?
[Re: Jerry]
#1241599
05/29/12 09:12 AM
05/29/12 09:12 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
Jerry, If the 650 that you found has the tuning "bells & whistles" on it for tuning your short term modification goals, then that might work. But if it is a basic 650 with no extra tuning capabilities, then I would suggest looking into a larger carb with tuning "bells & whistles" so that you can tune it through your short term and your long term performance changes.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Dragula]
#1241601
05/29/12 09:56 AM
05/29/12 09:56 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
how far off are your heads and cam?
that tells me that you should wait and spend money for a bigger carb instead of buying this one now that you're going to have to replace again later after the head/cam swap.
but...if it's going to be several years before you do the heads and cam, then go ahead and get the smaller carb now and get the car running right.
**Photobucket sucks**
[Re: Silverbullet2]
#1241604
05/29/12 01:37 PM
05/29/12 01:37 PM
Posts: 1,039 ALBERTA CANADA
CUDA8U
ALBERTA CANADA
If I wanted to make power I'd go with an 850.
a holley 850 can be "detuned a bit for now and leaves you lots more options for an upgrade in hp,and we all want more and more power!
[Re: dogdays]
#1241607
05/29/12 08:35 PM
05/29/12 08:35 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Not the best example but my buddy has run a 650DP on his 55 Chevy for years, it's a 427, turbo 400, 4:56 gears, 9x28 DOT slicks, he drives the car quite a bit & around town the small carb really helps drivability, at the track with the 650 he's run consistent 12.0's... With a 850 & lots of tuning he's run a 11.92... Personally I think a 650 would be fine for a healthy 383....
[Re: Jerry]
#1241609
05/29/12 09:37 PM
05/29/12 09:37 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
Jerry as has already been mentioned, most people tend to overcarb their engines, particularly street engines. For what I presume you're planning to do with your car the best thing you can do is go on the small side for a carb. You'll find it to be more responsive, particularly at low rpm's where you're likely to be spending most of your time. The reality is 6500-7000 rpm runs won't be happening so much for you that you'll miss the extra capacity.
I've been through this myself many times over the years, and in each case have found myself happiest with a street car running a 600-650 cfm vacuum secondary carb. I'm partial to Holley's myself. I've struggled with a few Edelbrock's and AFB's. I think the Holley's are easier to understand, particularly for an idiot like me.
Realize you're not talking that much money that you can't upgrade later on when you re-do the engine. There's always a good market for used Holley's. Once you've done the top end work, sell yours and go for a 750.
Lead, follow or get the hell out of the way
[Re: dobie]
#1241614
05/30/12 08:10 AM
05/30/12 08:10 AM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
I have a 650 DP on my warmed over 383. I also have a 750 DP which has been rebuilt by the guy who did the 650 DP for me. For some reason my car loves the 650. With the 750, it's harder to start, and just seems "off." Put the 650 back on, and she's ready to burn the tires off.
My car is the same way. She loves her 650. Easy start, better throttle response, and better ET's.
[Re: dustergirl340]
#1241616
05/30/12 08:54 AM
05/30/12 08:54 AM
Challenger 1
Cincinnati, Ohio
Many people overcarb...I've run a 12.40 in my Duster with a stock stroke 340 and Holley 650 carb.
I have holley 650 that I got on a 318 in a parts car, the carb looked brand new.
I got it out over the weekend and want to try it on my 340. But man is it hard to pull off a great running 600. Gonna try it here soon, maybe tonight.
