Rear main seal kit RB? #1241382
05/28/12 10:23 PM
05/28/12 10:23 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Whats the best rear main seal kit out there for a big block? I am so f'ing tired of these mother f'ers leaking I am gonna go insane!! Brand new motor with 4 passes and its leaking! The f'ing girdle is leaking too!
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Rear main seal kit RB? [Re: HOTMOPR] #1241383
05/28/12 10:42 PM
05/28/12 10:42 PM
IN
BIG BEAR Offline
BIG BEAR  Offline
IN
Best Machine sells one
Re: Rear main seal kit RB? [Re: BIG BEAR] #1241384
05/28/12 11:15 PM
05/28/12 11:15 PM
wine country
8
8urvette Offline
8urvette  Offline
wine country
hughes engines will be selling a 1 piece main seal soon.
Re: Rear main seal kit RB? [Re: 8urvette] #1241385
05/28/12 11:28 PM
05/28/12 11:28 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Ya I went to there site looking for it. I wonder when it will be for sale??
Re: Rear main seal kit RB? [Re: HOTMOPR] #1241386
05/29/12 12:18 AM
05/29/12 12:18 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
i know, i would be very tempted to pull my pan and put one in if its out in the next few days.... Its sitting on the stand, ready for it. if it were ready to be sold!
Re: Rear main seal kit RB? [Re: 8urvette] #1241387
05/29/12 03:35 AM
05/29/12 03:35 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Having trouble with one on a stock B engine as well. Going to change out in a week or two.
Leon
Re: Rear main seal kit RB? [Re: Leon441] #1241388
05/29/12 04:08 AM
05/29/12 04:08 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
fit a vac pump, problem solved
Re: Rear main seal kit RB? [Re: rebel] #1241389
05/29/12 06:45 AM
05/29/12 06:45 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
On my recent 440 build, I used the rear main seal and this set up from the FelPro gasket kit for the side seals. It consists of two pipe cleaners that you are supposed to dip in water. First, you fill the side cavities of the retainer with silicone, then push the wet pipe cleaners into the slot. It's supposed to cure the silicone since it requires moisture (never knew this). It sounded crazy to me, but I tried it anyway. I also siliconed around the outside of the seal where it meets the block and cap (I'm using a 440Source cap), and siliconed the cap to block mating surfaces. I have about 150 miles on it so far with not a drop of oil leaking.
Re: Rear main seal kit RB? [Re: rebel] #1241390
05/29/12 08:47 PM
05/29/12 08:47 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
I probably will need one of those too!! Just trying to figure out a low buck way to do it. Cant do the 900 bucks for one right now!
Re: Rear main seal kit RB? [Re: 8urvette] #1241391
05/30/12 12:04 PM
05/30/12 12:04 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Called this morning, 6-8 weeks is the expected delivery.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: Rear main seal kit RB? [Re: herkamer] #1241392
05/30/12 12:48 PM
05/30/12 12:48 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
So is this a cut circle and you wind it in?
Curious on this one...
OK, just checked it out on their site, Looks like quite a deal there.
If its sucessfull Ill buy one for the 440 for sure....
Re: Rear main seal kit RB? [Re: HOTMOPR] #1241393
05/30/12 03:09 PM
05/30/12 03:09 PM
I bought several,12, Federal Mogul rear main seal kits with the newer grey side seals, I fill the main seal holder edges to the block up with clear adhesive silicone and let it dry overnight before using them. I force the silicone into the bottom edges to the block also with a small flat screwdriver that fits bewteen the crankshaft flange and the block. I'll try posting a picture of it, hopefully that will help
Re: Rear main seal kit RB? [Re: herkamer] #1241394
05/30/12 08:15 PM
05/30/12 08:15 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I wouldn't get too excited about the so called "one piece" rear main seal. The problem isnt usually the parting points of the seal. In many cases its a poor finish of the seal surface on the Chinese stroker cranks. Also, AND THIS IS VERY IMPORTANT. If you are using tne replacement billet seal retainers cut some grooves in the retainer so that the oil can successfully drain back to the pan. If you install them you will see that the retainer winds up "shrouding" the #5 main cap and wont allow the oil to drain quickly back to the sump. The retainer that Best Machine sells is properly relieved to avoid this problem.
Also, the brown/orange "fluoroelastoimer" seal is the one to use. Its pricy at about 25 bucks, but I get no problems with this seal. Also, it should be a common practice by now to have a Chinese crank checked and corrected by a competent crank grinder before putting into use. Also ask the crank guy to check the rms surface. I usually have .005 cut off which tones down the heavy knurl they put into the rms surface.
MB
Re: Rear main seal kit RB? [Re: HPMike] #1241395
06/24/12 12:30 PM
06/24/12 12:30 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
MB
I used the orange "fluoroelastoimer" seal and so far it seems to be working well. The side seals take some time to "work" them into place. Use some silicone spray or WD-40 to lube the side seals, then have to raise-lower the seal retainer while pushing the side seals to work them down to the block surface.
Re: Rear main seal kit RB? [Re: 451Mopar] #1241396
06/24/12 12:45 PM
06/24/12 12:45 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
MB
Glad that worked
Its the only one I use at this point...
MB
Re: Rear main seal kit RB? [Re: Moparnut426] #1241397
06/24/12 05:22 PM
06/24/12 05:22 PM
good ole USA
moparlifer Offline
moparlifer  Offline
good ole USA
do you have to cut the crank off to get a one piece seal on a big block??? That Hughs is an intervator!
