Tail lamp lens restoration - anyone you recommend?
#1241282
05/28/12 07:24 PM
05/28/12 07:24 PM
Posts: 19,948 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
Any good recommendations for tail lamp lens restoration? I installed my NOS lens on the right side of the wagon, and now the left side looks like crap...well, not really like crap, just not as nice as the right side.
Also, any DIY products you recommend? My lenses have some chrome trim on them that will make buffing them with a machine kind of difficult, FWIW.
Earning every penny of that moderator paycheck.
DBAP
Re: Tail lamp lens restoration - anyone you recommend?
[Re: not_a_charger]
#1241283
05/28/12 07:34 PM
05/28/12 07:34 PM
Posts: 489 NE
bigtail
NE
Meguires Plast-X polish. You can hand buff it. I would do the NOS one as well. It had protectants in it. It is a miracle liquid.
This page is made up completely of recycled electrons.
[Re: autoxcuda]
#1241286
05/28/12 11:53 PM
05/28/12 11:53 PM
Work pretty decent. Seriously. Do a test section and see if it's what you are looking for.
But if you trying to get scratches out: wet sanding them with 400, 600, 1000, and 1500 grit or so will get scatches out. Then hand buff with medium paint rubbing compound, then fine compound. Should get it as nice an anyone else.
This or Mothers aluminum polish.
[Re: A12]
#1241289
05/29/12 12:45 AM
05/29/12 12:45 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
http://www.simichrome-polish.com/
Seriously it's the best out there....finished with simichrome
Wenol is very good too on plastic. My dad uses it on dull plastic headlight covers. Interesting to hear Wenol vs. Semichrome comparisions from people that have used both.
But those are just polishes. If you have significant scatches, like most do, you need to sand them out.
Wenol is pink colored and little thiner consistancy of toothpaste. IIRC, Simichrome is similar in those respects.
[Re: bigtail]
#1241290
05/29/12 02:17 AM
05/29/12 02:17 AM
Posts: 21,522 N.E. OHIO, USA
A12
N.E. OHIO, USA
On the plastic lens you can start with simichrome and then finish it with Mequires Plast-X polish. I used a loose buffing wheel on my '68 lens first with the simichrome and then Meg Plast-X came out nice. I did the same with my wife's Town and Country headlights after trying all of those headlight restoration kits and there was no comparison to simi and Plast-X
[Re: not_a_charger]
#1241292
05/29/12 07:50 AM
05/29/12 07:50 AM
autoxcuda
So Cal
I'll put Simichrome up against anything out there, including any of these "Johnny come lately's" .......
Simichrome is "metal" polish not aluminum polish that's why I feel for this application it is better for chrome restoration
I'm not polishing any metal or chrome. I'm only doing the red lens. The "chrome" pieces on my lens are plastic. Is a metal polish like Simichrome or Wenol safe to use on my plastic lenses?
I know Wenol is. I'm pretty sure Semichrome is too.
If you don't have one of those two on hand, I'd still do a little test spot with toothpaste and paper towel. Just to establish a baseline to measure the results of other products and/or processes. Will take a couple minutes; toothpaste and paper towels are super handy too.
[Re: not_a_charger]
#1241293
05/29/12 08:24 PM
05/29/12 08:24 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
I've used Simichrome also for years...It's a fine polish and you won't get into trouble using it on the plastic lenses around the vehicle...Never used the toothpaste trick so I can't comment on that....But no matter which polish you use be careful using any type of buffing wheel...Once you heat the lense and melt/disfigure the surface it's all over getting it to look like your nos piece...
[Re: not_a_charger]
#1241294
05/29/12 10:44 PM
05/29/12 10:44 PM
Posts: 12,153 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
As long as the red is still good, the best thing to do is to clear coat it. Glass bead it first so the clear can get a good gite. I've done this to many, many taillite lenses with excellent results.
It also works with many of the new headlights that get so cloudy. Sand them down good with 500 or so till smooth and use the left-over clear from a paint job to bring them back to life.
Master, again and still
[Re: not_a_charger]
#1241297
05/30/12 07:53 AM
05/30/12 07:53 AM
Posts: 892 MA
steve70
MA
Tape over the chrome to protect it before you bead blast.
1970 Challenger T/A 4 speed
[Re: not_a_charger]
#1241299
05/30/12 06:06 PM
05/30/12 06:06 PM
Posts: 489 NE
bigtail
NE
Always start with the least abrasive or damaging, and work your way up. If the plastic is in good condition, but hazy or dull, no deep scratches, I sure as heck would NOT start in by bead blasting it or sanding on it. Try some Plast-X with a micro fiber cloth and just work it in for a while by hand. If you have scratches or gouges, then is the time to use more abrasive techniques. Plast-X was made for plastic, it won't harm your chrome trim. I furnished my entire house with a lot of vintage 60s and 70s decor, much of it is pop-art plastic stuff. Some lucite sculptures, etc. Even the most clouded, crappy, dirty, very lightly scratched stuff came out looking brand new. Plast-X is outstanding stuff, and has preservatives and conditioners in it to protect the plastic. I did a set of vintage clear tinted pool table balls that most would have probably thrown away, and they came out looking like jeweled hard candies. Start off simple, then go rougher if you need to. Once plastic is removed, there is no putting it back. Good luck!
