Vibration problem #1241244
05/28/12 05:00 PM
05/28/12 05:00 PM
challconv70 Offline OP
I have a slight vibration at about 3300 RPM's, goes away at lower and higher RPM's, much worse in 4th gear, but present in other gears. Vibration is only present when foot is on the gas, under some load. Vibration has been there since car was restored.
I am running a MP 402 Crate with A833. I had the driveshaft balanced which did not fix it, I am thinking either balancer or something on transmission input shaft since it is present in all gears and only under load. Any way to figure out before I start swapping parts?
Re: Vibration problem [Re: challconv70] #1241245
05/28/12 06:28 PM
05/28/12 06:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you checked pinion angle?
Re: Vibration problem [Re: stumpy] #1241246
05/28/12 06:34 PM
05/28/12 06:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Chrysler issued a technical service bulletin in 1973 for vibration diagnosis, it is 20 pages long.
Go to http://www.hamtramck-historical.com/1974-Dodge-TSB-Index.shtml & drop down to Chapter 25 - see 25-02-74D
Re: Vibration problem [Re: challconv70] #1241247
05/28/12 07:04 PM
05/28/12 07:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is the 402 crate also new with the resto ?
Re: Vibration problem [Re: JohnRR] #1241248
05/30/12 10:39 PM
05/30/12 10:39 PM
Yes, vibe problem since 402 went in as well as other parts. Full resto.
Re: Vibration problem [Re: challconv70] #1241249
05/30/12 11:19 PM
05/30/12 11:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Then look at the motor as the source of the vibration . Did you have the engine built ? Is it external balance ??
