Water pump housing bolts #1241096
05/28/12 01:57 PM
05/28/12 01:57 PM
Washington
fish59 Offline OP
fish59  Offline OP
Washington
I purchased a 1969 water pump housing but it did not come with any bolts. I want to use stainless steel bolts for the housing and water pump. I see that there are many bolt kits online but I would rather just go to the local hardware shop and buy bolts. Does anybody know what length and size I would I need. I believe that they are all 3/8".
Thank you for your help!
Re: Water pump housing bolts [Re: fish59] #1241097
05/28/12 04:04 PM
05/28/12 04:04 PM
yes 3/8" bolts. You want 1/2" ~5/8" of thread engagement into the block. measure the housing dimentions & dont forget the gasket thickness
