Re: rebuilding a 46rh transmission. how to manual
[Re: Sinitro]
#1240572
05/27/12 09:14 PM
05/27/12 09:14 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
http://www.makcotransmissionparts.com/12400E-V.htmlvideo shows how to dissemble, inspect and rebuild the overdrive unit...the front half is a 727,, also cover the special tools needed...like a shop press... I used it and it made rebuilding 3 overdrive units easy.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Slipknot440]
#1240574
05/28/12 01:12 AM
05/28/12 01:12 AM
Posts: 2,588 missouri, USA
moparmojo
missouri, USA
I have a ram I used just for hauling stuff. Otherwise I don't drive it much, but it needs a trans rebuild too I think. Just don t want to pay for a rebuild that costs as much as the truck. Been wondering if I am up to trying my first trans rebuild.
[Re: 451Mopar]
#1240577
05/28/12 07:16 AM
05/28/12 07:16 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
front section is simular to a 727. You need a special compressor tool for the overdrive section, and it is under a large spring load so be careful.
You will need the alignment shaft too. Failure to utilize one and chances are you will not get the overdrive section back on the intermediate shaft.
[Re: gdonovan]
#1240578
05/29/12 02:45 AM
05/29/12 02:45 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Thanks, I forgot to mention the alignment shaft, we just use an old intermediate shaft cut to size.
