Big block heater control valve? #1240560
05/27/12 06:05 PM
05/27/12 06:05 PM
PA
noplanb Offline OP
noplanb  Offline OP
PA
Will the big block cooling system work with a simple shutoff valve in the heater core supply hose or does it require the bypass type valve to keep the coolant continuously circulating?
remember when you said honey, some day that car is gonna look so good in front of our house
Re: Big block heater control valve? [Re: noplanb] #1240561
05/27/12 06:17 PM
05/27/12 06:17 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Plug it/shut it off and GO!
