Best do-it-yourself exhaust manifold coating? #124033
09/21/08 06:53 PM
09/21/08 06:53 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
I just had my exhaust manifold glass-bead blasted and would like to put a high-temp paint or coating on it to prevent rust. Is there some easy & effective treatment I can apply myself, or would it be better to have it professionally done? Thanks for all replies.
Roger
Re: Best do-it-yourself exhaust manifold coating? [Re: Fab64] #124034
09/21/08 07:26 PM
09/21/08 07:26 PM
Iron Station, NC
furygt Offline
furygt  Offline
Iron Station, NC
Eastwood's seams to hold up better than most.
Bill
Re: Best do-it-yourself exhaust manifold coating? [Re: furygt] #124035
09/21/08 09:20 PM
09/21/08 09:20 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
Probably not the best thing out there, but I blasted mine with aluminum oxide and then painted them with stove black...
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: Best do-it-yourself exhaust manifold coating? [Re: Fab64] #124036
09/26/08 06:17 PM
09/26/08 06:17 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
DIY, Rust.
Re: Best do-it-yourself exhaust manifold coating? [Re: jcc] #124037
09/26/08 07:20 PM
09/26/08 07:20 PM
Texas, Dallas
G_T Offline
G_T  Offline
Texas, Dallas
You should try a ceramic coating - you can do it yourself (it sprays or brushes on) and withstands 2000F. There are several places that sell a variety of colors (cast iron, black, flat, white, chrome, blue, etc.). Although I have yet to use this - I plan to. Here is a place I found where you can buy the supplies: Columbia Coatings
Just go to the Ceramic section. I am sure there are other places out there that sell this stuff.
You may have an issue with your glass beading - might not give sufficient "bite" for the paint to adhere too.
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
Re: Best do-it-yourself exhaust manifold coating? [Re: G_T] #124038
09/27/08 06:04 AM
09/27/08 06:04 AM
MA
440beeper Offline
440beeper  Offline
MA
I've had good luck with Eastwood's coating... make sure you don't skimp on prep work. I had mine sandblasted and then sprayed with a cleaner (can't recall the name, but it was similar to brake cleaner....nasty stuff).
Re: Best do-it-yourself exhaust manifold coating? [Re: Fab64] #124039
09/27/08 08:07 AM
09/27/08 08:07 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Re: Best do-it-yourself exhaust manifold coating? [Re: furygt] #124040
09/27/08 08:14 AM
09/27/08 08:14 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Bill
Ive used this also, Works well.
Re: Best do-it-yourself exhaust manifold coating? [Re: AdamR] #124041
09/27/08 09:24 AM
09/27/08 09:24 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I used VHT manifold paint and it works pretty good.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Best do-it-yourself exhaust manifold coating? [Re: CJK440] #124042
09/27/08 01:38 PM
09/27/08 01:38 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I used eastwoods over 2 years ago and I drive this car regularly. Has held up very well. I did have them blasted first.
Re: Best do-it-yourself exhaust manifold coating? [Re: Pool Fixer] #124043
09/27/08 01:39 PM
09/27/08 01:39 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
There is one very small spot where I see rust coming through. but it's so small and has not spread. Im thinking about sanding it down and touching it up.
Re: Best do-it-yourself exhaust manifold coating? [Re: Fab64] #124044
09/27/08 02:35 PM
09/27/08 02:35 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
Mine still look good .... I used the eastwood coating about 14 years ago
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Best do-it-yourself exhaust manifold coating? [Re: doctor_mopar] #124045
09/28/08 05:28 PM
09/28/08 05:28 PM
AZ - The "dry heat" state
71autoxr Offline
71autoxr  Offline
Another vote for eastwoods. Mine is holding for 12+ years.
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: Best do-it-yourself exhaust manifold coating? [Re: 71autoxr] #124046
09/28/08 10:54 PM
09/28/08 10:54 PM
SW Minnesota
Dennis_K Offline
Dennis_K  Offline
SW Minnesota
I'm very happy with the results I got from POR 15 exhaust coating. I have about 2000 miles on mine and they look much better than my friend's manifolds with the Eastwood stuff on them, but I don't know if he did the prep work correctly. I'll try to remember to post a pic tomorrow.
I finally made it to the end of the rainbow. Murphy was standing there to tell me that the pot of gold was at the other end.
Re: Best do-it-yourself exhaust manifold coating? [Re: Dennis_K] #124047
09/29/08 06:28 AM
09/29/08 06:28 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Results will be much much better on a beefy iron manifold than a set of tube headers. I have found the BBQ paints hold up as well as the VHT stuff on exhaust parts.
Keep old mopars alive.
