727 front bushing #1240060
05/26/12 03:34 PM
05/26/12 03:34 PM
West Milton,Pa
cermac Offline OP
cermac  Offline OP
West Milton,Pa
This is 2nd new bushing And it's worn again. Trans leaking from front pump. New ATI 8" treemaster hooked to 416 ci with 620 hp and 550 fpt. Motor line bored and built 2yrs ago. Same tranny housing with block on new build. Only diff was old Lupo 9.5 " converter. Just switched to ATI, 7 passes, leak! Pressure tested converter. Ok! Tranny rebuilt this past winter. Put back together and bushing worn again and leaking. Are there manuals to show how to align housing with crank or any other suggestions. Thanks. Ps want to get to track!!! BSD in Pa
Re: 727 front bushing [Re: cermac] #1240061
05/26/12 04:31 PM
05/26/12 04:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With a dial indicator mounted to the crank and the
indicator on the outer pump bore(no conv or pump in
it) slowly turn the crank and see what you have...
might need to get a set of offset alignment pins...
also check the conv for run out on the input hub...
conv mounted to the crank and indicator mounted to the
block with the indicator on the hub... turn the crank
and see if its out
Re: 727 front bushing [Re: cermac] #1240062
05/26/12 05:25 PM
05/26/12 05:25 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
when the engine was align bored the crankshaft moved up in the block a small amount. as mentioned you need to check the crankshaft/transmission alignment
Re: 727 front bushing [Re: cermac] #1240063
05/26/12 05:32 PM
05/26/12 05:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Bronze bushing or babbit? Is the wear pattern all on one side or all around?
Re: 727 front bushing [Re: John_Kunkel] #1240064
05/26/12 07:57 PM
05/26/12 07:57 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I had a problem similar to this about 20 years ago. The problem ended up being that one of the alignment dowles was in the block a little to far. The chamfer on the pin combined with the chamfer on the bellhousing allowed the case to move around and not properly locate.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: 727 front bushing [Re: John_Kunkel] #1240065
05/26/12 07:59 PM
05/26/12 07:59 PM
West Milton,Pa
cermac Offline OP
cermac  Offline OP
West Milton,Pa
The wear pattern seems to be on opposite sides. For example at 12 o'clock and 6 o'clock. It's a clevite babbit.
The engine was rebuilt 2 years ago. We ran all year last year w zero problems. It seems weird that we would have problems now by just changing the converter.
Re: 727 front bushing [Re: turbobitt] #1240066
05/26/12 10:34 PM
05/26/12 10:34 PM
West Milton,Pa
cermac Offline OP
cermac  Offline OP
West Milton,Pa
Dowel pins are 1/4" out from block. Should be more?
Re: 727 front bushing [Re: cermac] #1240067
05/26/12 10:39 PM
05/26/12 10:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes about 1/2"... tap them out some
Re: 727 front bushing [Re: MR_P_BODY] #1240068
05/26/12 10:45 PM
05/26/12 10:45 PM
West Milton,Pa
cermac Offline OP
cermac  Offline OP
West Milton,Pa
How do I attach dial indicator to crankshaft. I have a magnetic mount for my gauge but not sure how to make that work.
Re: 727 front bushing [Re: cermac] #1240069
05/26/12 11:01 PM
05/26/12 11:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put the magnetic base on the back of the crank and
use a long arm to get the indicator out to the pump bore
Re: 727 front bushing [Re: MR_P_BODY] #1240070
05/26/12 11:28 PM
05/26/12 11:28 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
If only the chamfer part of the dowls are sticking out than you know its going to be trouble.
Allan G.
Re: 727 front bushing [Re: MR_P_BODY] #1240071
05/27/12 12:57 AM
05/27/12 12:57 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
with mr.p, i made my own dowel pins using a 1/2 bolt shank. mine are sticking through the trans case about 1/16". also use the trans case u are indicating to the crank.
Re: 727 front bushing [Re: MR_P_BODY] #1240072
05/27/12 10:17 AM
05/27/12 10:17 AM
NC
440Jim Offline
440Jim  Offline
NC
With a dial indicator ...
and see if its out
I like to see 0.003" TIR or less, 0.010" TIR is bad, inbetween is marginal.
Re: 727 front bushing [Re: cermac] #1240073
06/16/12 08:40 AM
06/16/12 08:40 AM
West Milton,Pa
cermac Offline OP
cermac  Offline OP
West Milton,Pa
For info, found crack at hub in converter! Originally tested with 20# pressure and found nothing. One company rep said that should be enough. Finally took contractor chalk and powdered converter and crack showed immediately. Called company again and rep who sold it to me said pressure test I did probably wasn't enough. They found crack and now deciding what to do! Under warranty! Only 15 runs! Having removed trans SIX times and replacing front pump and seals and bushings hopeful to get fixed.Thanks to all who helped here for input!
Re: 727 front bushing [Re: cermac] #1240074
06/16/12 09:27 AM
06/16/12 09:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The crack at the hub is SORTA common... it cracks
right next to the weld(heat affected zone).. I usually
check the converter with 125 psi... thats all the
pressure I have.... glad you found your problem
Re: 727 front bushing [Re: MR_P_BODY] #1240075
06/16/12 11:54 AM
06/16/12 11:54 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Mr. P what tool did u use to test the conv.?Is it something u fab. r purchase?......Thax
