440 Piston Rings #1239793
05/25/12 10:01 PM
05/25/12 10:01 PM
San Antonio, TX
CurYellowBird Offline OP
San Antonio, TX
Which way are you supposed to clock the 440 piston rings before dropping them in the hole?
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: 440 Piston Rings [Re: CurYellowBird] #1239794
05/25/12 10:54 PM
05/25/12 10:54 PM
PNW
Danan Offline
Danan  Offline
PNW
Everyone has their own preference. Doubt it matters so long as you don't line the gaps up. But I'm anal so I clock them all. If I'm installing a piston on the driver's side I put the top ring at about 11 o'clock, 2nd ring at about 7 o'clock, oil ring spacer at 3 o'clock, and the oil rings at 1 o'clock and 5 o'clock. This is assuming that 12 o'clock is pointing straight up (towards the intake manifold). In actuality, I think of the gap positions in terms of degrees rather than on a clock system, but it would be too difficult to explain that in written form. Basically, think of the top ring gap being at 30 degrees above the centerline of the piston, oriented to the front (probably closer to 10:30 rather than 11 o'clock). Hopefully you get the point..
Re: 440 Piston Rings [Re: Danan] #1239795
05/25/12 11:19 PM
05/25/12 11:19 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I don't see that it makes much of a difference seeing that they rotate with the movement of the piston. IMO you could put them in lined up (I wouldn't) and run the engine for 10 minutes - tear down and they would be nowhere near where you installed them
Re: 440 Piston Rings [Re: MoparforLife] #1239796
05/26/12 04:55 AM
05/26/12 04:55 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I thought that I read in my last set, the manufacturer wrote to oppose the 1st and 2nd rings, then put the oil ring gap in line with the top ring.
Top ring 12:00
Second ring 6:00
Oil ring 12:00
