Re: Lifter Bushing oil hole size..
[Re: AndyF]
#1239676
05/25/12 04:43 PM
05/25/12 04:43 PM
Posts: 4,210 New York
polyspheric
New York
The location of the hole can also be important depending on the lifters. X2 - I don't know of any bad choices in particular, but you should compare the tappet "waist" position and OAL to your tappet bores, allowing for whatever base circle and lobe height you'll be using.
Boffin Emeritus
[Re: Jeepmon]
#1239677
05/25/12 05:29 PM
05/25/12 05:29 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
BradH made me think of this question with his oil/bushing post..
What size hole do you drill into the lifter bushing on a RB block, when you're running a solid roller with pushrod oiling?
The oil passage from the #4 cam bearing has been blocked already.. I need to know what rocker system? T&D, Jessel or other?
Thanks in advance..
I had way more than enough oil on top for the rockers with the stock block. I pluged the oil holes in the head. I have only run it on the dyno but I had zero rocker issues.
What rocker system? T&D's, Jessel or other?
I have two .025" holes about 22.5* apart in a stock 400 block that is 498CID.
I have one .050" hole in my new KB block I just recieved.
The 498CID has run on the dyno for quit a while and it has had zero rocker issues.
[Re: Jeepmon]
#1239681
05/26/12 12:26 PM
05/26/12 12:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I put a .062 hole in the bushing BUT I'm running holes in the lifter to oil the axle and feeding the rockers via PR so I went with a little larger bushing hole... I think the axle feed hole is .015 and I have .040 restriction holes in the PR... I havent fired it up yet so I'm not sure if I will need to go to a high volume pump... I will see soon.... this is a 416ci
