Re: rotors......bare metal ,RPM or clear
[Re: burdar]
#1238467
05/24/12 08:01 AM
05/24/12 08:01 AM
Posts: 1,756 London, England
Gavin
London, England
RPM is great stuff, but just a thought - when it gets really hot I believe it re-liquifies, so unless someone can confirm it is not an issue, I'd be cautious on a rotor hub, for example, just in case it creeps onto the braking surface?
[Re: JohnRR]
#1238471
05/24/12 10:17 AM
05/24/12 10:17 AM
Some of you guys need to relax with this stuff. Just spray some cast grey hight temp paint in there and call it done. Who the heck is looking at your disc cooling fins?
[Re: A12]
#1238477
05/24/12 06:25 PM
05/24/12 06:25 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I sprayed the stock solid rotors on the rear of an 04 Dakota with regular spray paint. the pads wiped of the paint from the swept surface quickly, but the paint stayed everywhere else, and never burned off.
I would go with a high temp engine paint if you're that worried about it. most spray bomb ceremic paints claim to be good for up to 500-600 degrees. how hard are you going to be pushing your car? how hot do you anticipate getting the rotors?
**Photobucket sucks**
