rotors......bare metal ,RPM or clear #1238463
05/23/12 09:24 PM
05/23/12 09:24 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
For those of you with front disc brakes...how are you keeping the rotors looking new? They will start looking bad right away if I install them right out of the box. The temps will be very high so I'm guessing RPM will just burn right off. How about masking off the pad contact surfaces and spraying them down with a high temp clear?
What are you using?
Re: rotors......bare metal ,RPM or clear [Re: burdar] #1238464
05/23/12 09:33 PM
05/23/12 09:33 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I'd go with RPM. BTW, even high temp clear will burn off
Re: rotors......bare metal ,RPM or clear [Re: burdar] #1238465
05/23/12 09:48 PM
05/23/12 09:48 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I saw a magazine article, I think Mopar Action, said to try spraying hi temp paint down into the fins.
Re: rotors......bare metal ,RPM or clear [Re: 71birdJ68] #1238466
05/23/12 09:52 PM
05/23/12 09:52 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
The fins are what I'm worried about the most. They'll start looking scaly in a hurry. Maybe do a combination of RPM and clear?
Re: rotors......bare metal ,RPM or clear [Re: burdar] #1238467
05/24/12 08:01 AM
05/24/12 08:01 AM
London, England
Gavin Offline
Gavin  Offline
London, England
RPM is great stuff, but just a thought - when it gets really hot I believe it re-liquifies, so unless someone can confirm it is not an issue, I'd be cautious on a rotor hub, for example, just in case it creeps onto the braking surface?
Re: rotors......bare metal ,RPM or clear [Re: Gavin] #1238468
05/24/12 09:55 AM
05/24/12 09:55 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
That was my thought as well. I'm also worried about it attracting dust once it liquifies. If all my parts turn into big dirt balls I'm going to be .
Re: rotors......bare metal ,RPM or clear [Re: burdar] #1238469
05/24/12 10:03 AM
05/24/12 10:03 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How about lightly spraying in there with a high temp gray paint ?
Re: rotors......bare metal ,RPM or clear [Re: JohnRR] #1238470
05/24/12 10:16 AM
05/24/12 10:16 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Any suggestions are welcome John. Maybe I should just install them and not worry about it. There's going to be about a 3/16" ring between the pad contact surface and the edge that will get rusty anyway. I just thought someone might have a magic solution.
The gray paint idea is a good one. The rotor would probably start to rust under a clear pretty quickly. A gray paint would keep it looking nicer longer.
Re: rotors......bare metal ,RPM or clear [Re: JohnRR] #1238471
05/24/12 10:17 AM
05/24/12 10:17 AM
Some of you guys need to relax with this stuff. Just spray some cast grey hight temp paint in there and call it done. Who the heck is looking at your disc cooling fins?
Re: rotors......bare metal ,RPM or clear [Re: ] #1238472
05/24/12 10:19 AM
05/24/12 10:19 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I'm looking at them.
Why else am I going to all this other work making the car look nice? I need to be happy with it once it's done.
Re: rotors......bare metal ,RPM or clear [Re: burdar] #1238473
05/24/12 10:38 AM
05/24/12 10:38 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
PlastiKote Cast Gray.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: rotors......bare metal ,RPM or clear [Re: burdar] #1238474
05/24/12 10:39 AM
05/24/12 10:39 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Find a set of stainless steel rotors (like dirt bikes use you'll never see rust on them DAMHIK) and be done with it.....BTW they won't stop anywhere near what a cast iron rotor will but hey they'll always look pretty and won't rust
Re: rotors......bare metal ,RPM or clear [Re: hemi71x] #1238475
05/24/12 03:48 PM
05/24/12 03:48 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I think it's duplicolor that has a dark iron color high temp paint,, that looks convincingly similar ( not same as ) untreated bare iron
once the wheel is on in the ft and dust shields on to cover the back , most will never catch they are painted
Re: rotors......bare metal ,RPM or clear [Re: gtx6970] #1238476
05/24/12 05:08 PM
05/24/12 05:08 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Another cast paint that I really like is VHT
Re: rotors......bare metal ,RPM or clear [Re: A12] #1238477
05/24/12 06:25 PM
05/24/12 06:25 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I sprayed the stock solid rotors on the rear of an 04 Dakota with regular spray paint. the pads wiped of the paint from the swept surface quickly, but the paint stayed everywhere else, and never burned off.
I would go with a high temp engine paint if you're that worried about it. most spray bomb ceremic paints claim to be good for up to 500-600 degrees. how hard are you going to be pushing your car? how hot do you anticipate getting the rotors?
**Photobucket sucks**
Re: rotors......bare metal ,RPM or clear [Re: 70Cuda383] #1238478
05/24/12 07:13 PM
05/24/12 07:13 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Just normal driving for this car. Still, rotors get really hot. I just wanted to know what others were doing.
