My 410 Magnum on the engine dyno #1238372
05/23/12 07:13 PM
05/23/12 07:13 PM
lino lakes,MN
onebaddakota Offline OP
lino lakes,MN
I'm heading to the dyno. This a 40 over magnum 360 with 4" forged crank,H beams, and flat tops. It retains the factory hydr. roller setup. The cam is a racer brown 248/252@50 with 608 lift. Compression came in at 11.8:1. Carb is a 950hp.It's also on E85. Intake is a ported M1 with a fully ported eddy magnum that flows 290s at 600 lift. Headers are a little bit of a compromise. They are a midlength with 1 3/4 primary and 3" collector. The cam is a little bit out there for the factory hydraulic roller stuff. I don't know of anyone running that much lift on a magnum set up. To control it, I'm running a nitrided PAC beehive with titanium retainer and a stud girdle.It's on the racier side for a magnum to be sure. I don't know really know what to expect.There's just not a ton of info on magnums with this type of build.
Place your bets boys!
10.56 at 125.6, with a 1.43 60 ft. E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
Re: My 410 Magnum on the engine dyno [Re: onebaddakota] #1238373
05/23/12 09:25 PM
05/23/12 09:25 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
about 530hp I am guessing!
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: My 410 Magnum on the engine dyno [Re: wldtm] #1238374
05/24/12 03:02 AM
05/24/12 03:02 AM
Renton Washington
Triple Threat Offline
Renton Washington
545hp
How does this compare to the old engine combo that put down the times in your sig?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: My 410 Magnum on the engine dyno [Re: Triple Threat] #1238375
05/24/12 07:17 AM
05/24/12 07:17 AM
Guitar Jones Offline
563hp/577tq
Re: My 410 Magnum on the engine dyno [Re: Triple Threat] #1238376
05/24/12 10:42 AM
05/24/12 10:42 AM
lino lakes,MN
lino lakes,MN
545hp
I never dynoed it, Dustin, so I have no idea.
Re: My 410 Magnum on the engine dyno [Re: onebaddakota] #1238377
05/24/12 10:45 AM
05/24/12 10:45 AM
Maryland
Sick 660r Offline
Sick 660r  Offline
Maryland
I'll take a guess. 594 with a dominator
2000 dakota 418 magnum paxton novi 2k T56
Re: My 410 Magnum on the engine dyno [Re: onebaddakota] #1238378
05/24/12 11:12 AM
05/24/12 11:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
530 hp... are you going to dyno it
Re: My 410 Magnum on the engine dyno [Re: Sick 660r] #1238379
05/24/12 12:02 PM
05/24/12 12:02 PM
lino lakes,MN
lino lakes,MN
You funny
Re: My 410 Magnum on the engine dyno [Re: onebaddakota] #1238380
05/24/12 12:09 PM
05/24/12 12:09 PM
lino lakes,MN
lino lakes,MN
I didn't really know what to expect with this motor as some of it is a bit unproven. Would I have a stable valve train to 6500? How bad would the heads and hyd roller hold me back?
Well we get it warmed and start loading it up and seems a little rich we pull 3 jets and make our first clean pull to 6300rpm. 555 Hp I'm happy with that. I was hoping for 550HP after all was said and done. The motor liked 34 degrees.
We were now on to carb spacers. I was prepared to be unimpressed. We put a 1" super sucker 4 hole. We let her buck and were stunned to see: 582HP@6300 and 532 TQ@ 5300
The dyno shop says he sees that type of gain about once a year. He theorized that it was a fuel distribution problem given the extra volume needed to run E85.
We threw a dominator on just for fun and made 594HP!!Tq went up to 543@5300
Ron told me to throw some real headers on for an easy 600+.
I am blown away by those numbers. Myself and the others were pretty sure it wouldn't make over 550. Does this sound right to you guys? Did the E85 pick me up that much?
I asked Ron at R and R about his dyno-whether it was a "happy dyno" or not. He told me he dynos more motors than anyone in the midwest and if anything; it's stingy! I guess will see when it slips into the truck.
Re: My 410 Magnum on the engine dyno [Re: onebaddakota] #1238381
05/24/12 01:25 PM
05/24/12 01:25 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Yep, those hyd rollers don't work...
Nice job, hope it runs as good as the dyno numbers show.
Maybe a 1 3/4-1 7/8 step, 35-36" and 3.5 collector might work well. Straight 1 7/8", same lengths and collector would be pretty good too.
Re: My 410 Magnum on the engine dyno [Re: onebaddakota] #1238382
05/24/12 01:26 PM
05/24/12 01:26 PM
Louisiana
Red440 Offline
Red440  Offline
Louisiana
That is some very nice #'s you should be Happy ! I will bet you are ready to bolt it in the Dakota. Are you going to have to make any converter and gear changes ? Nice combo, good luck.
Re: My 410 Magnum on the engine dyno [Re: Red440] #1238383
05/24/12 02:02 PM
05/24/12 02:02 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Good show !!!!
Re: My 410 Magnum on the engine dyno [Re: Wedgeman] #1238384
05/24/12 02:07 PM
05/24/12 02:07 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
I like it! very nice
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: My 410 Magnum on the engine dyno [Re: Red440] #1238385
05/24/12 06:48 PM
05/24/12 06:48 PM
lino lakes,MN
lino lakes,MN
I run an ATI treemaster 8" with a 4400 stall. It should do nicely with this combo. I run the stock 3.92 gears and 8 1/4 axle. It's the same unit that came in the truck in 92. I just can't kill it. I think things are a changing though.
Re: My 410 Magnum on the engine dyno [Re: onebaddakota] #1238386
05/24/12 08:12 PM
05/24/12 08:12 PM
Renton Washington
Renton Washington
I'm impressed. What does the truck weigh and what was the old engine combo?
Re: My 410 Magnum on the engine dyno [Re: onebaddakota] #1238387
05/24/12 08:56 PM
05/24/12 08:56 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
nice little pc
Re: My 410 Magnum on the engine dyno [Re: fishy340] #1238388
05/24/12 09:53 PM
05/24/12 09:53 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
Good results!.
Can't wait to see the time slips.
Re: My 410 Magnum on the engine dyno [Re: onebaddakota] #1238389
05/24/12 10:47 PM
05/24/12 10:47 PM
gregsdart Online content
gregsdart  Online Content
Very good numbers! I am sure it will run as strong as the numbers show.
Re: My 410 Magnum on the engine dyno [Re: Triple Threat] #1238390
05/24/12 11:07 PM
05/24/12 11:07 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Wow nice numbers. Good luck with it.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: My 410 Magnum on the engine dyno [Re: Triple Threat] #1238391
05/25/12 12:29 AM
05/25/12 12:29 AM
lino lakes,MN
lino lakes,MN
With me in it about 3400lbs. The old combo was a 408 with the same heads,intake, and carb. cam was 236/242 with 579 lift. Compression was 10.0 with dished pistons. Best time in sig. It was probably a 500 HP motor, give or take a few.
