Re: A-Body Leaf Springs - why do mine look crooked?
[Re: Kern Dog]
#1238336
05/23/12 09:40 PM
05/23/12 09:40 PM
Posts: 1,460 oklahoma
forphorty
oklahoma
What if a previous owner had a B body 8 3/4 in there and they just spread the springs wide to fit INSTEAD of relocating the perches?
That's what i'm thinking.
[Re: 340duster340]
#1238340
05/24/12 04:33 PM
05/24/12 04:33 PM
Posts: 25 Glendora, CA
MYBD318
Glendora, CA
A-body spring perches are 43" center to center 2 cents
Still a teen just a 416
[Re: ScottSmith_Harms]
#1238341
05/24/12 04:36 PM
05/24/12 04:36 PM
Posts: 1,152 Colorado
CuriousYella70
Colorado
Are you sure its an original unmodified A- body rear end?
It's an A-Body 8 3/4 from a 71 340 Duster a guy in Northern Colorado had. Was told that it was bone stock and had a friend rebuild it. I do know he used big bolt fury axles in it (have the big bolt front end and wanted the big bolt in the rear) but that's not going to change anything on the width of the rear end would it?
[Re: MYBD318]
#1238342
05/24/12 04:37 PM
05/24/12 04:37 PM
CuriousYella70
Colorado
I'll have to measure this later tonight when I get home.
[Re: CuriousYella70]
#1238343
05/25/12 12:56 AM
05/25/12 12:56 AM
Posts: 438 Great Lakes Region
abodiesonly1
Great Lakes Region
If someone used big bolt pattern Fury axles, its not an A Body rear. This is providing no one cut the rear and/or the axles.
[Re: abodiesonly1]
#1238344
05/25/12 01:38 AM
05/25/12 01:38 AM
Posts: 27,483 So Cal
autoxcuda
So Cal
I'm going to guess the axles were cut down. The big C-body axles are meaty where the new splines need to go.
And if it was a C-body rear he wouldn't be able to get the rear rims on his car with anywhere near the offset I've seen in pictures of his car.
#1238346
05/25/12 03:51 PM
05/25/12 03:51 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
what was wrong with this statement? A-body spring perches are 43" center to center. Should be the only measurement you need for now.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#1238348
09/07/12 10:54 AM
09/07/12 10:54 AM
CuriousYella70
Colorado
Finally got around to measuring the rearend, had to deal with 4 speed issues first. From the center of the perch stud that goes through the leaf springs, mine measure just under 44" - about 2 marks below the 44" mark on the tape measure. So obviously, this isn't a stock A-Body rearend. Is it a B-Body rear end being so close to the 44" mark?
What's the best solution to fixing this and making the rear end work? I've seen where people just grind off the perches and move them in - is that something I should do? Move them in until they center out at 43"? Thoughts??
#1238349
09/07/12 11:03 AM
09/07/12 11:03 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
it's a B body rear more than likely , now WHICH one is the question 66-67 or 68-70 , the 68-70 is wider than the 6566 , but both are wider than an A body .
You could just leave it be, many guys run it like that with no issues , if you believe everything you read on the internet...
Which begs the question , why did it need new cut down axles ? Did it have small bolt pattern axles in it originally ? If so maybe it is an A body rear that someone moved the perches on to put it in a 66-67 B body at one time ???
#1238350
09/07/12 11:22 AM
09/07/12 11:22 AM
Posts: 15,487 Florida
scratchnfotraction
correct 44" spring perch center are from a early B-body A-body perch centers are 43" centers. measure the backset on your rims. measure from axle flange to axle flange...drum to drum I had a C-body housing cut to A-body specs for large brake axles,it made the whole rear end wider a 1/2" 1/4" each side if the axles are cut to A-body specs 28" then a 4.5 backset on the rim is whats needed the duster/darts have a much bigger wheel opening and will allow a B-body houseing fit in by spreding the springs apart a 1/2" each side this makes the spring look like yours does. sloping outward. i have done this to a few a-bodys. My cut down C-body to A-body spec housing with moser large brake/large wbp axles use a 4.5 backset with the springs on 43" centers. in the dart 7" rim 4.5" BS 245/60/15 the same A-body 8 3/4 bolted in my 88 440 truck 12" rim with 4.5" BS 29x15x15 M/T I wager you have a B-body housing with the 44" spring perch centers. or if it A-body spec axle/housing the perches are set for a B-body and mini tubbing wheel wells.
#1238351
09/07/12 11:47 AM
09/07/12 11:47 AM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Using your garden variety home improvement store made in china type of tape measure, that would be 43 7/8" If you have a much earlier model, made in USA type tape, it may be 43 15/16. Using a machinist scale it could be 43 31/32. You'll need to define that level of accuracy to best figure out spring spacing, pad location, and wheel offset to create the best combination. Telling a welder to put the pads two ticks off of something won't work.
