door lock removal-47 desoto? #1238222
05/23/12 03:04 PM
05/23/12 03:04 PM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
i`m trying to remove the lock on the door of my 47 desoto, anyone know how its done?
Re: door lock removal-47 desoto? [Re: 65rbdodge] #1238223
05/23/12 04:30 PM
05/23/12 04:30 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
That's not a 47 in your avatar.
Remove inner door panel.
Feel behind the lock. It will have a big nut (unlikely), a clip (very likely) or a sleeve with a set screw that is accessed from the door face with the latch.
In all cases, once the retainer is loosened of removed, the lock must be carefully moved and twisted to unhook the linkage and slide out the hole.
Re: door lock removal-47 desoto? [Re: RodStRace] #1238224
05/24/12 08:29 AM
05/24/12 08:29 AM
n.e. pa.
n.e. pa.
i have it all apart, it looks like there is a sleeve with a set screw in it, facing the door jam. it looks like there was an access hole there but has a small piece of metal welded over it.
