BEST SEALING TIMING COVER FOR RB 440??? #1237796
05/22/12 06:58 PM
05/22/12 06:58 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Any suggestions on a reasonably-priced cover for my 440? I've used the MP chrome piece and it seemed to be OK. Is a cast aluminum cover worth the x-tra money? Thanks!
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: Labratt] #1237797
05/22/12 07:34 PM
05/22/12 07:34 PM
AndyF Offline
AndyF  Offline
Yes, the cast covers will seal better than the tin covers. But some of the cast covers won't fit under a stock water pump, and some of them don't have a TDC pointer. So you have to pay attention to the details. My billet cover has an extra thick rail so it seals up very well, but it isn't "low budget".
http://arengineering.com/products/timing-chain-cover/
Re: BEST SEALING TIMING COVER FOR RB 440??? *DELETED* [Re: AndyF] #1237798
05/22/12 08:05 PM
05/22/12 08:05 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Post deleted by Al_Alguire
RIP Monte Smith
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: CompWedgeEngines] #1237799
05/22/12 08:23 PM
05/22/12 08:23 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Randy, as Andy mentioned some won't fit under a stock water pump without a spacer. I don't recall what balancer you are using, but ATI sells a specific one for the Indy cover.
Competition Wedge, I have one of the stock covers on my "wall of shame"! Live and learn.....
Randy
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: Labratt] #1237800
05/22/12 09:14 PM
05/22/12 09:14 PM
NC
440Jim Offline
440Jim  Offline
NC
I have always used the stock timing cover. Sand and paint has worked for me. Chrome anything can be hard to hold a gasket.
Re: BEST SEALING TIMING COVER FOR RB 440??? *DELETED* [Re: 440Jim] #1237801
05/22/12 10:04 PM
05/22/12 10:04 PM
Syracuse,NY
Syracuse,NY
RIP Monte Smith
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: CompWedgeEngines] #1237802
05/22/12 10:57 PM
05/22/12 10:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your still solid cam however right?
Randy(LabRat) is also
Re: BEST SEALING TIMING COVER FOR RB 440??? *DELETED* [Re: MR_P_BODY] #1237803
05/22/12 11:58 PM
05/22/12 11:58 PM
Syracuse,NY
Syracuse,NY
RIP Monte Smith
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: CompWedgeEngines] #1237804
05/23/12 12:08 AM
05/23/12 12:08 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Promax sells a nice cast cover with seal for $100 but you'll need to add a pointer. It fits under the waterpump. You need to trim back the oil slinger if you're going to use one as it will rub the cover.
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: Stanton] #1237805
05/23/12 12:46 AM
05/23/12 12:46 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Randy, we used a 440Source tin cover on the 572 and it is heavier guage than the stocker. Dwayne had no concerns using it with the roller cam/thrust button setup and felt it would be reliable. Mine was slightly warped and needed some attention to seal it up but it's been fine and leak free since the dyno session.
Ron
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: 440Jim] #1237806
05/23/12 01:54 PM
05/23/12 01:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Exactly, another smart FAST racer who doesn`t buy the b.s. hype........mines fine after 13+ years and my cam doesn`t budge w/a slightly pre-loaded rollerized button..........
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: Labratt] #1237807
05/23/12 02:00 PM
05/23/12 02:00 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The only reason why I'm switching to an AR Engineering setup is because I wanted something "a little" more sophisticated to go w/ my conversion from flat-tappet to roller cam. Otherwise, I'd stick the same OEM cover back on I've used "forever..." w/o any leakage issues.
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: BradH] #1237808
05/23/12 02:03 PM
05/23/12 02:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Then by all means spend the extra coin and get one...........
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: Thumperdart] #1237809
05/23/12 02:17 PM
05/23/12 02:17 PM
BradH Offline
BradH  Offline
...and my cam doesn`t budge w/a slightly pre-loaded rollerized button....
Isn't there supposed to be a minimal amount of free play between the button and the cover, rather than pre-loaded against it?
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: BradH] #1237810
05/23/12 02:19 PM
05/23/12 02:19 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Just going by what Isky said...........it`s rollerized so why would you need clearance?
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: Labratt] #1237811
05/23/12 02:56 PM
05/23/12 02:56 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I've never used anything but a stock cover.
Rich H.
Esse Quam Videri
Re: BEST SEALING TIMING COVER FOR RB 440??? *DELETED* [Re: BradH] #1237812
05/23/12 03:05 PM
05/23/12 03:05 PM
Syracuse,NY
Syracuse,NY
RIP Monte Smith
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: CompWedgeEngines] #1237813
05/23/12 03:41 PM
05/23/12 03:41 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yes of course the timing cover flexes, but a stock type water pump housing does an admirable job at stopping it.
Of course this means dinking around for awhile, spending time on it, adding a piece of metal between the two parts that is just the right thickness to take up the space, without killing the clearance.
For a guy working out of the garage at home on a budget, where time is more plentiful than money....when the money spent might mean the difference between buying something more important he should absolutely spend the time dinking around with it and get it right, it will cost him next to nothing and he can set the cam end play wherever the heck he wants.
For a pro where time is money, whatever time you spend checking/correcting anything old is probably more expensive than the most expensive brand new part you could get...so anything old does not make sense from that perspective....in that situation stock timing cover is best used as a frisbee, or (preferably) give it away to one of us guys working at home in the garage.....
Rich H.
Esse Quam Videri
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: CompWedgeEngines] #1237814
05/23/12 03:43 PM
05/23/12 03:43 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Dont worry...the stock covers flex enough to make clearance.... ....and people wonder why their timing isnt stable, their gears wear out and other sorts of thing....when you see motors that run 300-400 passes a year...then some of this stuff starts to make sense. But what do I know. Carry on......I'm just a money waster I guess....
think he got ya on that one DOM
this is a solid Milodon Cover with not enough end play...
Mopar Performance
Re: BEST SEALING TIMING COVER FOR RB 440??? *DELETED* [Re: ZIPPY] #1237815
05/23/12 04:03 PM
05/23/12 04:03 PM
Syracuse,NY
Syracuse,NY
