A-833 weak link? #1237729
05/22/12 01:37 PM
05/22/12 01:37 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
Since I have my transmission apart, (18 spline A-833) I will be rebuilding it (sorta), i want to know what should I change, if anything, in this trans to improve its strength?
The synchros all look great, the sliders are the same, it has steel forks in it, and the bearings are tight- so ill be doing a gasket kit.
when i pulled it apart, it was apparent that it has been rebuilt before, and doesn't have a bunch of miles on it.
What should I do? and No i wont be doing the slick shift upgrade
Re: A-833 weak link? [Re: 8urvette] #1237730
05/22/12 01:39 PM
05/22/12 01:39 PM
Fairhope, Alabama
BeeSuper Offline
BeeSuper  Offline
Fairhope, Alabama
What is the slick shift upgrade?
Re: A-833 weak link? [Re: 8urvette] #1237731
05/22/12 01:49 PM
05/22/12 01:49 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Check for rounding of the dog teeth of on each gear. If they aren't sharp, you'll be grinding when shifting gears.
Re: A-833 weak link? [Re: BeeSuper] #1237732
05/22/12 10:50 PM
05/22/12 10:50 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
where every other tooth is removed the the schynro slider, allows easier power shifting
Re: A-833 weak link? [Re: Dave Watt] #1237733
05/22/12 11:17 PM
05/22/12 11:17 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
anybody ever sharpen there on dog teeth? or just throw the gear away?
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: A-833 weak link? [Re: kilroy] #1237734
05/23/12 12:13 AM
05/23/12 12:13 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You ARE kidding, right ?!?!?
Re: A-833 weak link? [Re: kilroy] #1237735
05/23/12 09:58 AM
05/23/12 09:58 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Dremel tool with a cut off wheel, a little patience and it can be done. I've done many. The trans in my car now was done by me last winter.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: A-833 weak link? [Re: 68LAR] #1237736
05/23/12 11:36 AM
05/23/12 11:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Same here , dremel and a small stone , clean up the grinding that had occured .
