Page 3 of 5 1 2 3 4 5
Re: help me ID the inside of this distributor... [Re: JohnRR] #1237644
05/23/12 02:00 PM
05/23/12 02:00 PM
hooziewhatsit Offline
It's still not idling as smooth as I would expect, especially based on some other videos I've seen posted of 360's with this same cam. Also, I'm not understanding how/why it will idle the BEST with 30 degrees advance
You need to bring the RPM up and see what the timing is doing! If it keeps advancing you are going to have a huge problem when it tries to run with almost 60 degrees advance , nevermind when the vacuum can starts adding more ...
heres something dumb I didn't ask , can you see the springs on the advance weights when you look down inside the distributor ?
No kidding! Wouldn't that be something if the springs were both missing/broken
And Cal, I was in your same spot ~5 years ago. Used carb on a used intake, and it ran like poo Couldn't touch the throttle for 10 minutes while it warmed up, and it still drove like crap. Eventually I figured out each little issue, and it drives almost perfectly now. Keep at it
Re: help me ID the inside of this distributor... [Re: cal_gecko] #1237645
05/23/12 02:00 PM
05/23/12 02:00 PM
Sacramento, CA
cal_gecko Offline OP
Sacramento, CA
OK... I did some more tweaking .. got it to 15 degrees advance at idle.. it struggles, but it'll stay idling, but fluctuates between 800-1000
Re: help me ID the inside of this distributor... [Re: cal_gecko] #1237646
05/23/12 02:04 PM
05/23/12 02:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I listened to the video , something is not right it should not be idling like that .
Can you borrow a carb from someone ?
And I can't see the springs in that shot above , they are under the plate.
Re: help me ID the inside of this distributor... [Re: JohnRR] #1237647
05/23/12 02:05 PM
05/23/12 02:05 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I can't watch the video at work. I'll give it a shot on my phone when I go to lunch.
- Stu Harmon
Re: help me ID the inside of this distributor... [Re: RobX4406] #1237648
05/23/12 02:06 PM
05/23/12 02:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
plus get that timing dialed back once you get the gap set.
WRONG!!!
Fix/weld the mechanical advance plate so the engine can have the proper initial.
Carry on
No , not really.
That is something he could/should eventually do but for right now to figure out what is going on he needs to keep it no higher than 5-8 .
How much total it has right now don't mean jack shyat...
He needs to get his idle issue sorted out and TOTAL plays absolutely no part in that area of the equation. Time that car at 5-8* initial and it will run worse than he could ever imagine.
I guess we will have to agree to disagree, there is no way that cam he has needs 30 degrees of initial timing to run right .
Re: help me ID the inside of this distributor... [Re: JohnRR] #1237649
05/23/12 02:21 PM
05/23/12 02:21 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
WRONG!!!
Carry on
No , not really.
Now that I agree with. It should run in the 14-18* range pretty easily IF everything is right. Total doesn't matter here, second piece of the ignition timing puzzle. He's not driving it, nor putting any load on it.
If that car starts easily with 30* initial on it, it's got no cylinder pressure. He had it apart and from what I understand didn't bother to degree the cam with the old timing set nor the new one...
I wonder if he fixed any of the other issues he had from the other threads. I'll bet one particular big one is still left unresolved.
Re: help me ID the inside of this distributor... [Re: JohnRR] #1237650
05/23/12 02:23 PM
05/23/12 02:23 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
That is ODD, Its like someone is barely touching the throttle every few seconds. Like something is binding up and letting go, Do you have another Carb and Distributor laying around?
This may sound dumb, but also do you have a different MSD box, I have had a few MSD boxes turn my hair grey from similar BS issues.
Just a thought...
Good luck and stick with it.
Re: help me ID the inside of this distributor... [Re: Moparnut426] #1237651
05/23/12 02:39 PM
05/23/12 02:39 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Are you running the car on the factory tank or a gas can? Did the car have old gas in it? or is it a new tank with new gas?
Are all the grounds good on the ignition box, motor, and battery?
Did the carb sit for a long period of time with old gas in the bowls? Are the carb butterflies closed all the way or hung up on a gasket?
Did you try spraying carb cleaner around the intake and carb bases to check for a air leak?
Are the sparkplug wires tight on the plugs, maybe a bad set of wires even though they are new?
Re: Continuing with the troubleshooting... distributor... [Re: cal_gecko] #1237652
05/23/12 03:08 PM
05/23/12 03:08 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have 3 or 4 spare electronic distributors to try.....
Re: help me ID the inside of this distributor... [Re: moparpollack] #1237653
05/23/12 03:23 PM
05/23/12 03:23 PM
Sacramento, CA
Sacramento, CA
factory tank.. we took it out and looked in it - it was in great shape inside.. there was barely any gas left in it, and about 8 gallons of new fuel was put into it.
As far as I know... I can add that to the list of things to check, just to tighten them down.
It did sit for a while.. I went through it about 2 years ago, cleaned it all out and put in new gaskets.. but after that, it was just started a couple times. Good question about the carb butterflies.. I haven't looked at that.
I did.. it seems to be ok.. when I'm spraying around the carb, it does increase idle a bit, but I think that is from overspray making it into the top of the carb.
I have swapped to an entirely new set of Accel 8mm wires, and have made sure all wire ends are secure on the plugs...
The compression test? I haven't had time to do that.. by the time I get home from work, it's 8pm at the earliest.. that's gonna have to wait until the weekend for me to do..
Doesn't sound dumb.. it's not the first time someone's mentioned it.. I don't have a spare MSD box, and since I don't have all the other Mopar electronic ignition stuff (ballast resistor, control box, wiring), I can't just disconnect the MSD box to see if it'll work without it
I don't..
I may take you up on your offer for assistance, now that I'm back to troubleshooting all the stuff on the 'outside' of the engine... you wouldn't happen to have a spare carb, too for testing purposes - would ya?
Re: help me ID the inside of this distributor... [Re: cal_gecko] #1237654
05/23/12 03:31 PM
05/23/12 03:31 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Spare carburetors? Uhhh, no. I DO have a Holley 600 on my bro-in-laws 360, a Holley 750 on my own 67 Dart with a 360 and an 850 on the Charger. I'd be willing to pull them to test on your car if you need. ALL are square bore carbs like the standard Edelbrock pattern.
Just a thought... MY 360 in the 67 Dart is a reringed, stock piston '79 360 with '308 heads and a 280/474 cam. It idles pretty smoothe and makes great power. Very little lope. Stock points ignition. That may be an apples to oranges comparison though.
Re: Continuing with the troubleshooting... distributor... [Re: cal_gecko] #1237655
05/23/12 03:36 PM
05/23/12 03:36 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Oh yeah... I also have a ThermoQuad on a 440 in my '74 truck if you need a spread bore carb.
I had an AVS rebuilt at the Carburetor Factory on Antelope. They went through it TWICE and it still ran terrible. It wouldn't idle below 1200, it was choppy and it stalled often when put into gear. I pulled that T-quad from a '80 318 in a van at pick-n-pull and the truck runs great!
Want to buy an AVS cheap?
Re: help me ID the inside of this distributor... [Re: Kern Dog] #1237656
05/23/12 03:44 PM
05/23/12 03:44 PM
Sacramento, CA
Sacramento, CA
I would think the 750 may be too much carburetor for my engine - but obviously, I'm no expert The heads on yours might work better than the stock heads on mine for that much fuel.. I dunno ???
Re: Continuing with the troubleshooting... distributor... [Re: Kern Dog] #1237657
05/23/12 03:51 PM
05/23/12 03:51 PM
Sacramento, CA
Sacramento, CA
You need to work on your sales pitches!! This sounds very similar to the problem I'm already having.. I don't need to add to it!
Re: Continuing with the troubleshooting... distributor... [Re: cal_gecko] #1237658
05/23/12 04:38 PM
05/23/12 04:38 PM
Moparnut426 Offline
Moparnut426  Offline
Ill tell ya what Cal, Ive been wanting to stick a stroked gen 3 HEMI in my demon for a while. Ill sell ya a nice HARD runnin 408 for your car, and Ill stick a HEMI in my Demon.... Carb to pan,
DEAL????
Re: Continuing with the troubleshooting... distributor... [Re: Moparnut426] #1237659
05/23/12 04:59 PM
05/23/12 04:59 PM
Sacramento, CA
Sacramento, CA
DEAL????
How much?
Re: Continuing with the troubleshooting... distributor... [Re: cal_gecko] #1237660
05/23/12 05:08 PM
05/23/12 05:08 PM
Moparnut426 Offline
Moparnut426  Offline
1 MILLLLLION DOLLARS!!! lol
Id hate to tell ya cause its a nice piece, and was a fortune to build LOL
Re: Continuing with the troubleshooting... distributor... [Re: Moparnut426] #1237661
05/23/12 10:30 PM
05/23/12 10:30 PM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
Hey all, I'm going to throw my worth in. Take that distributor apart and make sure it doesn't have a really weak spring. Could be allowing timing advance too low. Or coming in at or below your idle speed. If you haven't done that already.
Re: Continuing with the troubleshooting... distributor... [Re: superbeedave] #1237662
05/23/12 10:35 PM
05/23/12 10:35 PM
Sacramento, CA
Sacramento, CA
Superbeedave - thanks.. I do see the timing advance via the mechanical when it hits between 1200-1500 rpm... isn't that where it should start to kick in?
Re: Continuing with the troubleshooting... distributor... [Re: cal_gecko] #1237663
05/23/12 10:49 PM
05/23/12 10:49 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yes that's correct! Let me think about your problem for a bit!
