Hughes performance converters #1237475
05/22/12 12:33 AM
05/22/12 12:33 AM
littlestown pa
dustpan man Offline OP
littlestown pa
Has any one ever had any problems with them and whats the hp rateing on the 904 3500 stall I think my converter isint puting the power to the trans like it should be just a ?
Re: Hughes performance converters [Re: dustpan man] #1237476
05/22/12 01:16 AM
05/22/12 01:16 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I'm using the 10" 3000 stall converter, got it from Summit. No issues here..
Re: Hughes performance converters [Re: dustpan man] #1237477
05/22/12 10:09 AM
05/22/12 10:09 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I ordered a lockup converter from them due this week, so far I have not been impressed with the service.
I'm being diplomatic and will say nothing further till the converter arrives and is given a go. When you screw up how well the mess is cleaned up tells you volumes about the company.
Re: Hughes performance converters [Re: gdonovan] #1237478
05/22/12 10:25 AM
05/22/12 10:25 AM
littlestown pa
littlestown pa
Well the trans ant sliping ! I got 355 gears and 28"tall tires top speed should be around 140 at 6000rpms when I ran my car this past weakend I ran 12.10 @110 I was turning 6000 at the trap so the converter I think is bad is that right ?
