cudadon-rough day at the office yesterday #1237424
05/21/12 11:06 PM
05/21/12 11:06 PM
Park Forest, IL
slantzilla Online content OP
slantzilla  Online Content OP
Park Forest, IL
Saw Don out at RT66 yesterday, some friends were pitted across from him.
Car came back from the 1st round on the rollback. Gasket blew out on the oil filter and Don got in his oil and scuffed the wall pretty good.
He was fine, all the safety equipment worked like it was supposed to. Wall saved the car from going over, and there was no fire.
Re: cudadon-rough day at the office yesterday [Re: slantzilla] #1237425
05/21/12 11:15 PM
05/21/12 11:15 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
WOW sorry to hear in that.. Isn't this the new Barton motor.
Re: cudadon-rough day at the office yesterday [Re: slantzilla] #1237426
05/21/12 11:31 PM
05/21/12 11:31 PM
Az
Crizila Offline
Crizila  Offline
Az
Sorry to hear that. Give him my regards please Dennis. I raced last Friday and Saturday nights at Firebird ( yes, it was hot ) and didn't have very good outings ether. Went out first round both nights. I'm having major problems with this detroit locker I am using. I have some good video of burnouts and launches where both tires aren't locked up - at least not initially. It's making for goofy ( can't keep the car straight ) burnouts and inconsistant ET's. Had the starter pooping in his pants once. Gonna put my rebuilt clutch unit back in this week. Might have to try some spider gear welding soon. How's the wiring coming along?
Fastest 300
Re: cudadon-rough day at the office yesterday [Re: Crizila] #1237427
05/21/12 11:43 PM
05/21/12 11:43 PM
Park Forest, IL
Park Forest, IL
Will do John. Hope you get yours straightened out.
Al, yes it is. Don't think he hurt the motor, but not sure.
John, I've been racing my AWD Dakota. Hook is not an issue.
Re: cudadon-rough day at the office yesterday [Re: slantzilla] #1237428
05/21/12 11:47 PM
05/21/12 11:47 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Sounds like my Thanksgiving at Farmington last year. Hope the damage isn't to bad..
5.53 @ 125 1/8th on the launch control..more left in her!
Re: cudadon-rough day at the office yesterday [Re: slantzilla] #1237429
05/21/12 11:51 PM
05/21/12 11:51 PM
Az
Crizila Offline
Crizila  Offline
Az
A little off topic, but the wife had a good outing. Made over $450 for "Team Firebird".
Fastest 300
Re: cudadon-rough day at the office yesterday [Re: slantzilla] #1237430
05/22/12 12:31 AM
05/22/12 12:31 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I hate to hear these things about ANY racer and what the hell`s going on w/oil filter gasket blowouts lately...........I run the K&N`s and I OVER tighten em and they don`t even so much as weep oil......
Re: cudadon-rough day at the office yesterday [Re: Thumperdart] #1237431
05/22/12 10:35 AM
05/22/12 10:35 AM
tboomer Online work
tboomer  Online Work
Dennis...I hope Don is ok...What kind of filter was he running?
Re: cudadon-rough day at the office yesterday [Re: slantzilla] #1237432
05/22/12 10:45 AM
05/22/12 10:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Bummer that he got into the wall... hopefully it isnt
much damage
Re: cudadon-rough day at the office yesterday [Re: Thumperdart] #1237433
05/22/12 10:47 AM
05/22/12 10:47 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
My thoughts too,,,what IS going on with the filters lately?? I have never had this happen. I use Wix 51515R filters...
If you like drag racing, support your local track.
Re: cudadon-rough day at the office yesterday [Re: Thumperdart] #1237434
05/22/12 10:49 AM
05/22/12 10:49 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Filters need to be more than hand tight imo.
Then it might be a good idea to switch to a aftermarket filter like a Oberg or a Filter One that is made a little better.
Re: cudadon-rough day at the office yesterday [Re: Challenger 1] #1237435
05/22/12 11:04 AM
05/22/12 11:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Well if you give it a 1/2 turn after contact thats
.031 compression of the rubber gasket... thats ALOT...
what I have seen in some of the filters is the lip
or bump in the metal isnt much and the compression
of the rubber will start to push the gasket out if
the outer lip isnt big enough(out side lip od the
gasket area)... if the oil pressure is 80# that lip
should be plenty... if its over 100# it might not
be enough to hold the gasket
Re: cudadon-rough day at the office yesterday [Re: CHAPPER] #1237436
05/22/12 11:09 AM
05/22/12 11:09 AM
Az
Crizila Offline
Crizila  Offline
Az
There is a big disparity in filter quality - but then there always has been. If you have ever actually cut some appart and compared things like wall thickness, base plate thickness, crimp quality, filter media, visual flow paths, base gasket retention, you would be shocked at the quality differences amongst some name brands. If you are not paying over $10 for your oil filters, you are buying junk - in most cases. They will usually work fine in your normal every day driver though - maybe only one out of ten will leak I like Moroso, K&N, Mobile 1, to name a few quality oil filters. There are still no guarantees when you run high oil pressure.
Fastest 300
Re: cudadon-rough day at the office yesterday [Re: slantzilla] #1237437
05/22/12 12:47 PM
05/22/12 12:47 PM
Hobart,Indiana
MoparPitBull Offline
Hollywood
Hollywood
Hobart,Indiana
Thanks to all you fellow racers for concerns for Don. My name is Dave and I am the wrench for the Barracuda Boys. Yes it was a bad weekend;Saturdays race, win a round, burn the trans up. We thrash to remove it, go to CRT for a replacement(Thanks Big John),Re-install, fire up at 11 at night and put in the trailer. Good to go and confident! Sunday off the trailer 9.17@144...Hot Damn! First round, well Don is ok and Barracuda will be back! You can count on it! As far as the oil filter, it was an aftermarket canister type with removable screen assembly. Didn't like from the beginning...too small;will not be going back on.
Re: cudadon-rough day at the office yesterday [Re: Crizila] #1237438
05/22/12 01:14 PM
05/22/12 01:14 PM
organ
maximum entropy Offline
organ
this is 100% true! it's amazing what is (and what is not) in some filters.
Re: cudadon-rough day at the office yesterday [Re: maximum entropy] #1237439
05/22/12 04:40 PM
05/22/12 04:40 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
That is a real bummer, still i'm glad Don is ok, please give him my sympathies as well.
Mick from England
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: cudadon-rough day at the office yesterday [Re: deaks] #1237440
05/22/12 04:45 PM
05/22/12 04:45 PM
Renton Washington
Triple Threat Offline
Renton Washington
That really sucks. Sorry to hear about the damage, glad he's ok. The car can be fixed.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: cudadon-rough day at the office yesterday [Re: Triple Threat] #1237441
05/22/12 11:38 PM
05/22/12 11:38 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Man,sorry to hear about this. Sounds like a bad weekend all around! Glad Don is ok. The car can be repaired.
Re: cudadon-rough day at the office yesterday [Re: fbs63] #1237442
05/24/12 12:37 AM
05/24/12 12:37 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
thanks to all for your concern and kind words.
yes it couldve been A LOT worse.
working on getting back to track as we type thanks don
Re: cudadon-rough day at the office yesterday [Re: cudadon] #1237443
05/24/12 10:06 AM
05/24/12 10:06 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Hey Don if you need any help just holler i will be there
