Vacume pump pickup location...Hemi #1237416
05/21/12 10:34 PM
05/21/12 10:34 PM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
Hey Guys,
Just curious....about vacume pump pickup location's on a Hemi...
Got a Hemi...Stage 5 milenium head with the T&D (Ray Barton) rocker setup...
Im picking up alot of oil in my catch can...pretty sure its am inlet location problem...those T&D spray bars do a great job of oiling but are a pain with this....
Anybody else with the same combo? Curious as to where you put your bung for the pickup to avoid excessive oil problems..
Thanks guys...(and gals!)
Re: Vacume pump pickup location...Hemi [Re: WH23H6] #1237417
05/22/12 06:17 PM
05/22/12 06:17 PM
Smithfield, Rhode Island
Mulehead Offline
Mulehead  Offline
Show location on my Hemi
Ain't nuthin like a HEMI !
Re: Vacume pump pickup location...Hemi [Re: WH23H6] #1237418
05/22/12 06:25 PM
05/22/12 06:25 PM
an8sec70cuda Offline
Mine is on top the valve cover b/t the #1 and #3 intake rockers. Doesn't pick up a lot of oil there. I have standard oiling though, no spray bars.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Vacume pump pickup location...Hemi [Re: an8sec70cuda] #1237419
05/22/12 07:54 PM
05/22/12 07:54 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
when first installed mine was one the front of the valve cover using Reheer-Morrison baffle/. Blew oil all over the motor and car.15" was too much for a single Changed to double lines all OK now.
home of the
Sox and Martin Hemi Duster
Re: Vacume pump pickup location...Hemi [Re: HEMIFRED] #1237420
05/22/12 11:20 PM
05/22/12 11:20 PM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
Somebody else told me that today as well...makes sence...same vacume signal but 1/2 the velocity..got things apart now and changing things around...
Mine did the same thing...blew oil everywhere at about the 800 ft mark...got under the tires...other than a half hour track cleanup and ruining a perfectly good pair of underware...no damage done..scary ride!
Re: Vacume pump pickup location...Hemi [Re: WH23H6] #1237421
05/23/12 12:40 AM
05/23/12 12:40 AM
Addison,IL
OUTLAWSSAA Online content
OUTLAWSSAA  Online Content
Addison,IL
Driver side valve cover. Milenium heads
Re: Vacume pump pickup location...Hemi [Re: OUTLAWSSAA] #1237422
05/23/12 02:02 AM
05/23/12 02:02 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well here is a pic from when we had an old school Hemi in the Barracuda. Drivers side valvecover and relief is on the pass side. I have since put ALL my relief valves on the pump itself.
Re: Vacume pump pickup location...Hemi [Re: WH23H6] #1237423
05/23/12 04:59 AM
05/23/12 04:59 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
about the same as mine did.
at first I thought it was the baffel turned upside down with opening facing upwards. So I flipped it then took the car to the dyno made 3 pulls. not a single drop of oil leaking anywhere. next day went to Maple Grove and oil again. By now it was pretty evident that the one thing we could not duplicate on the dyno was deceleration.
home of the
