HEMI BUILD HP
#1237291
05/21/12 06:08 PM
05/21/12 06:08 PM
Posts: 253 Smithfield, Rhode Island
Mulehead
Building a new Hemi motor,4.310 bore X 4.500 stroke,Callies crank Oliver rods Diamond pistons 13.7 Alcohol heads 230,194 valves 170 chamber Cam lift 7.38 intake 7.14 exhaust 108 indy intake 3 1050 holley.Your thoughts on Hp?To make it easier for you 525 ci
Ain't nuthin like a HEMI !
Re: HEMI BUILD HP
[Re: Dragula]
#1237298
05/25/12 12:46 PM
05/25/12 12:46 PM
Mulehead
You can see the crack in a other rod.I was told the new motor could be in the 800 hp range.
