Vinyl Roof Contact Cement Removal #1237286
05/21/12 06:01 PM
05/21/12 06:01 PM
Central Coast, Calif.
Snoopy Offline OP
Snoopy  Offline OP
It's been a while since I first asked this question and I was hoping someone might have come up with a new product or procedure to remove the contact cement on the roof without damaging the paint on the roof. The car was repainted about 10 years ago.
Re: Vinyl Roof Contact Cement Removal [Re: Snoopy] #1237287
05/21/12 06:29 PM
05/21/12 06:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Rather DANGEROUS, but I've always used gasoline to remove vinyl top glue, esp the factory stuff, without damaging the paint, I apply a small amount to a rag then just work a small area at a time, time consuming, but I find it doesn't ruin the paint, just use a good paint prep wax and grease remover to remove the petroleum residues
Re: Vinyl Roof Contact Cement Removal [Re: DAYCLONA] #1237288
05/21/12 08:29 PM
05/21/12 08:29 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I use the 3M adhesive remover and a scotch brite pad.
Re: Vinyl Roof Contact Cement Removal [Re: DAYCLONA] #1237289
05/21/12 08:40 PM
05/21/12 08:40 PM
Snoopy Offline OP
Snoopy  Offline OP
I believe the contact cement is by 3M. I had the top replaced when I had the car painted.
The guy that replaced the top did a bad alignment job and the results were less than acceptable. The seams are wavy. He blamed it on the manufacturer and they blamed it on the installer. So I am stuck in the middle. That was 10 years ago and I have been ignoring it all these years.
Thanks for the suggestion, I will try it and see how it works for me. I was hoping for a magic liquid that you brush or spray on and wipe off the glue.
Re: Vinyl Roof Contact Cement Removal [Re: Snoopy] #1237290
05/21/12 09:59 PM
05/21/12 09:59 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Let me know how that works. The guy that installed my top didn't trim it in the right places. Now I have a lot of glue at the bottom of the A-pillars I have to remove.
