What pressure to sand blast? (HF pressure blaster) #1237214
05/21/12 04:42 PM
05/21/12 04:42 PM
Vicksburg, MI
coffeeman383 Offline OP
Vicksburg, MI
I use this Harbor Freight sandblaster to blast with black grit/slag from Menards. I go about 100 psi and occassionally the hose will burst (and sand the floor or my legs). The manual says never go above 125 psi.
Any recommendations? I've got a new/stonger hose from Mcmaster-Carr but I can't get the clamps tight enough over the barbs to prevent leaking.
Re: What pressure to sand blast? (HF pressure blaster) [Re: coffeeman383] #1237215
05/21/12 04:45 PM
05/21/12 04:45 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
I think the harbor freight instructions say 90 psi. I have not always had the best luck witH mine. One moment it is blasting great the next, not so great. Still working the bugs out.
Re: What pressure to sand blast? (HF pressure blaster) [Re: coffeeman383] #1237216
05/21/12 04:51 PM
05/21/12 04:51 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I blast plastic at about 40 PSI and slag like what your trying to shoot at 75 PSI max on a car body with lot's of volume.
You are wasting your time with that sorry excuse for a tool. My
A tool rental for the blaster and compressor would be a much better deal and you would get it done in one day instead of never.
Re: What pressure to sand blast? (HF pressure blaster) [Re: Challenger 1] #1237217
05/21/12 06:58 PM
05/21/12 06:58 PM
Oklahoma
V
VoodooCLD Offline
VoodooCLD  Offline
V
Oklahoma
Go buy some real heavy industrial hose clamps. then take off the lower manifold and drill out the horizontal body (parrallel to the ground). I took it about as far as i felt safe with, which was pretty far. I have not had one clog since i did that. I use the black stuff from tractor supply. It works really well. I had to play with the lower sand control setting a bit, but now that its dialed in i never touch it.
I run around 80-100 psi. whatever my main regulator is set at at the time!
Re: What pressure to sand blast? (HF pressure blaster) [Re: VoodooCLD] #1237218
05/22/12 06:47 PM
05/22/12 06:47 PM
KS
MoparKansas Offline
MoparKansas  Offline
KS
Clogging is likely due to moist air. When I first got my HF blaster it clogged all the time. I purchased a good water separator (cost as much as the blasting unit) and haven't had a problem since.
Re: What pressure to sand blast? (HF pressure blaster) [Re: MoparKansas] #1237219
05/22/12 06:51 PM
05/22/12 06:51 PM
Oklahoma
V
VoodooCLD Offline
VoodooCLD  Offline
V
Oklahoma
Ya i forgot to mention. I run like 30 feet of hose, then into a regulator/water seperator, then about 50 ft to the regulator/water seperator on the sandblaster. It still clogged until i drilled out that manifold.
Re: What pressure to sand blast? (HF pressure blaster) [Re: VoodooCLD] #1237220
05/22/12 10:28 PM
05/22/12 10:28 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
been using the same blaster where i work for about 5 years. air going into blaster is 120 lbs, go higher the air safety valve pops open.
we use only silica sand in it.
perception is 90% of reality
