Page 2 of 4 1 2 3 4
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: JoesMopar] #1236795
05/22/12 12:01 AM
05/22/12 12:01 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
lol
I ran them too for years, but when I quit using them my engines were better and lasted longer without the additional stress on the drive and less windage, from my experience.
What does that mean "my engines were better"how do you know they "lasted longer" because of the oil pump?How did you monitor it to decide this?
Were all other things like tune-up,oil quality,oil filter,oil brand,oil type,type of driving equal?
Why did you decide to "stop using them"?What does "less windage" mean?
I'm confused.
John
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: jcastle1] #1236796
05/22/12 12:16 AM
05/22/12 12:16 AM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
i just can't understand how an increase of 2-300 rpm can change the pressure so drastically, cruising down the highway i can gradually increase rpm from 3300 to 3500 and watch the pressure drop, step on it a bit more and drop to 25-30psi.I'm scared to push it to 4-5000rpm now
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: CUDA8U] #1236797
05/22/12 12:38 AM
05/22/12 12:38 AM
i noticed my oil pressure start to drop around 3500 rpm and drop rapidly to 25psi on hard accel beyond 3500
stock pan,hv pump
not sure what clearance was set on pump/pan
Which motor and body style are you having the problems with?
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: Cab_Burge] #1236798
05/22/12 01:15 AM
05/22/12 01:15 AM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
stock pan,hv pump
body style?
440, stock pan , hv pump
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: CUDA8U] #1236799
05/22/12 03:17 AM
05/22/12 03:17 AM
stock pan,hv pump
body style?
What year 440 motor and what year and body style is the car, last thing, does the oil pan have a number stamped in it on the bottom side? If so what number is it? If no numbers can you take a picture of it( the oil pan) and add it on here on your next post? I hope so No oil or low oil pressure can be very damaging to your motor, don't ask me how I know that I have a box of broken parts from racing them Mopar V8, BB, SB and 426 Hemi motors
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: jcastle1] #1236800
05/22/12 08:16 AM
05/22/12 08:16 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
lol
I'm confused.
John
Ever twisted a drive? You learn lot's at the track that you will never learn on the street.
I have built 4 BBC for my dragsters and would have lot's of oil in my catch tank at the end of the run with a HV oil pump. Warren Gross who helped me build my first BB suggested that I don't use it back around 1992. So I did build 3 more BB with standard pumps and there was lot's less oil in my catch tank after each run. I also would look down at the end of the run to see hardly any oil pressure with HV pumps(even with huge dragster oil pans), I had way more pressure at the end of a run with a standard pump. This was after bracing the stock pump to kkep from cracking it off the rear main cap which happened twice to me before I braced my pumps on BBC. Then I went with external belt driven pump which was even better with big strock cranks.
Since then I have built 3-340s 2 440s, a couple of diesel engines, and some motorcycle engines. Not to mention many BAE hemis.
Does that help any?
I drove my latest 340 at Bonneville at near wide open throttle for over 5 miles at a time with a standard oil pump and it held up fine in 95 degree weather, twice that day with no oil pressure problems. That's a serious workout at wide open throttle for miles at a time.
Almost 5 minutes later at 120 mph. Wonder how many cars and motors out there would stand up to this kind of use?
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: JoesMopar] #1236801
05/22/12 08:57 AM
05/22/12 08:57 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
Get rid of the HV pump, overfilling the stock pan doesn't sound like a "fix" to me.
That's only to see if that is the problem. If it is then you put on a bigger sump pan.
Overfilling the stock pan doesn't matter when there's not enough oil in it at 3500 RPM and up.
I run a 498 Hemi with a Milodon single line swinging pickup and it will lose pressure with any less than 7 quarts of 20-50 VR oil in it.
NMCA NSS 67 Coronet
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: Barry70GTX] #1236802
05/22/12 09:05 AM
05/22/12 09:05 AM
Cincinnati, Ohio
Cincinnati, Ohio
I ran 18 quarts of oil in my 10 quart hemi pan, that's what it took to keep oil pressure through out the run with 60 pounds of boost which keeps the oil suspended in the crankcase. It got replaced every run too.
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: Barry70GTX] #1236803
05/22/12 09:09 AM
05/22/12 09:09 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I don't think oil volume is the problem. it's either the pump, or something is plugging the pickup/filter.
he's putting in 5 LITERS of oil, that's more than 5 quarts.
**Photobucket sucks**
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: 70Cuda383] #1236804
05/22/12 10:54 AM
05/22/12 10:54 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
1 litre is approximately 1 US quart . . .
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: a12rag] #1236805
05/22/12 10:57 AM
05/22/12 10:57 AM
Cincinnati, Ohio
Cincinnati, Ohio
yup 1.05668821 quart
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: Challenger 1] #1236806
05/22/12 12:24 PM
05/22/12 12:24 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
The old HV pump myth.
two identical engines, same oil, same temperature one with a HV pump, one with a standard pump. both at 3000 rpm, both with 70# oil pressure. guess which one has more oil flowing through the engine? NEITHER
the ONLY time a HV pump is pumping more oil through the engine is if the pressure is higher...period
put on a stock pump with an 80# relief spring in it, it makes 80# of OP, then put a HV pump with a 60# spring on it and it makes 60# of OP, guess which one is pumping more oil THROUGH the engine THE STOCK PUMP
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: CUDA8U] #1236807
05/22/12 01:27 PM
05/22/12 01:27 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The pickup is clogged, the pickup is too far off the bottom of the pan, there is a hole in the pickup or another air leak in the suction side of the system/sucking air somewhere, O ring between the two halves of the oil pump has failed, or similar problem.
whether it is called HV or not means diddley squat in this discussion
Rich H.
Esse Quam Videri
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: ZIPPY] #1236808
05/22/12 02:11 PM
05/22/12 02:11 PM
P
Paul_Fancsali Offline
P
Fully agree with not running a HV pump stock pan is being sucked dry if its a good pump. As long as you got at least 25 lbs at speed no harm done yet!
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: Paul_Fancsali] #1236809
05/22/12 11:28 PM
05/22/12 11:28 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Volume and pressure are two totally different things.
As for the "if it runs better with the extra quart of oil"....why would you go through the hassle of swapping out an oil pan instead of just pulling the externally mounted HV pump? The HV pump has NO added value to the engine in question....it's a gimmick.
My opinion.....put on the stock oil pump and be done with it, get back to us on your results. Or, you can screw around with it for days on end and waste time swapping oil pans, pan gaskets, etc etc etc. I'm interested in your results whichever direction you choose to go. Good luck
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: Paul_Fancsali] #1236810
05/23/12 12:06 AM
05/23/12 12:06 AM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
definately a noisier engine with the pressure drop
surely someone has had a stock pan and hv pump with this problem before,I guess i'll try the stock pump but don't want to sink a pile of money into this engine since I'm planning a 493 stroker kit for this engine this winter which brings another whole set of questions
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: CUDA8U] #1236811
05/23/12 12:09 AM
05/23/12 12:09 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Yeah.....that was me...
383, stock 4 quart pan, windage tray, HV pump, 440 Source Heads. The drainback sucked.
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: JoesMopar] #1236812
05/23/12 12:12 AM
05/23/12 12:12 AM
jamesc Offline
jamesc  Offline
they may be totally different things but they are directly related. all else being equal the only way to increase oil flow through an engine is to increase the oil pressure. if the stock pump makes the same oil pressure as the HV pump then the flow through the engine is identical and the HV pump has absolutely nothing to do with "sucking the pan dry" as so many people seem to think.
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: jamesc] #1236813
05/23/12 12:19 AM
05/23/12 12:19 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Im sure you are sucking the pan dry....
My first 440 w/high pressure pump and a hv pump would suck the stock pan dry...
Did it too many times to count....never spun a bearing...but the bearings looked horrible when I tore it down. But, the bearings were shot well before I started sucking her dry....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: OIL PRESSURE DROPPING AT HIGHER RPM [Re: JoesMopar] #1236814
05/23/12 12:25 AM
05/23/12 12:25 AM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
so what solved the problem for you?
Page 2 of 4 1 2 3 4
