I'm having a hard time figuring this thing out, especially since it doesn't seem to match up with the 68 schematics in my FSM. One thing that really has me going is the time delay relay plug (I think that's what it is) which takes a three-prong componant. My FSM shows it as having a two-wire setup and yet I've got this three prong plug. Is it for something else? Can you help me identify these wires and where they go? Again, the main ones I'm having trouble with are the two plugs at the top of the pic.
What I think is correct:
1. The yellow door switch wire is the one going out the pic frame to the left (which by itself in my new M&H harness) and back to the map light switch.
2. The double pink wires with the female spade connector go to the fuse block with one powering the switch and the other going to the three-spade mystery plug.
3. The socket and female bullet plug go to the switch,
