Re: Trans cooler ahead of radiator or after?
[Re: DGS]
#1236720
05/21/12 11:26 AM
05/21/12 11:26 AM
Posts: 2,826 NY usa
540challenger
NY usa
on the other hand when the water temp is up it will heat the tranny fluid if the cooler is before the radiator...
I recently got a transmission cooler with a thermostat that I plan on mounting after the radiator. The thermostat only opens when the tranny fluid reaches a certain temp so no worries about too cool fluid.
Wouldn't that cut off the fluid flow when t-stat is shut???
[Re: 540challenger]
#1236721
05/21/12 11:55 AM
05/21/12 11:55 AM
Posts: 636 Graz, Austria
DGS
Graz, Austria
No, as the thermostat has an internal bypass. It acts as a short piece of pipe when it's closed. when it opens the internal bypass is closed and the fluid has to go through the transcooler.
I'm going to use a Mercedes A-class transmission cooler. here's a pic:
[Re: DGS]
#1236722
05/21/12 12:47 PM
05/21/12 12:47 PM
Posts: 2,826 NY usa
540challenger
NY usa
Now that is a cool piece. Do you have a part number for that cooler??
[Re: 540challenger]
#1236723
05/21/12 03:37 PM
05/21/12 03:37 PM
DGS
Graz, Austria
I sure do - here it is: (A) 169 500 06 00 I accidently put up the picture of the newer cooler style. my cooler has part numer (A) 169 500 04 00 (or A 169 500 02 00). here's how mine looks like (a bit different than the one before):
