Re: 3G HEMI 1st time to track
[Re: 69dart]
#1236543
05/20/12 08:57 PM
05/20/12 08:57 PM
Posts: 453 Holly, MI
JackGTX440
Holly, MI
How do you like the fast xfi? That is what is going on my turbo 6.1. I had emailed fastmanefi a number of times about it. He's a super helpful guy!
Jack Irons Jr.
'67 GTX, turbo 6.1 HEMI
[Re: 340RICK]
#1236547
05/20/12 09:29 PM
05/20/12 09:29 PM
Posts: 304 Maryland
SLEDGEHAMMER
Maryland
Great job Rick!!! Looks like your gonna be one of those tuner guys soon enough. Don't be scared to change things around you are only one file away from getting back where you were.
1971 Dodge Dart - Powerplant <<TBD>>
[Re: 340RICK]
#1236548
05/20/12 09:39 PM
05/20/12 09:39 PM
Posts: 16,925 NC
440Jim
NC
Made 2 easy passes lifting at the 1/8th. Foot braked the car leaving at 2000rpm shifted 6500 went 6.55 in the 1/8th....NO issues with car
That is a good start, confidence is high?
So leave at 2000 again shift at 7000RPM went 10.21 at 133mph with a 1.49 60ft
Not a bad run, the sixty foot wasn't as good as expected. But maybe some starting line technique (transbrake, stage rpm, etc. will wake that up pretty easily). I would have been pretty careful on that day. So I think you did very well being careful and the best is yet to come.
[Re: 440Jim]
#1236549
05/20/12 09:45 PM
05/20/12 09:45 PM
Posts: 16,925 NC
440Jim
NC
I love the new 3G Hemi. I think it has great potential and fun for Mopar racers in the coming years. I keep good notes, but check/add to this one. What are the basics? 426? CR, 727, gear, converter, etc. Quote:
6.1 block 4.065 I bought the Manley rotating kit 4.050 stroke 48lb crank Manley H beams 2.00" x 6.125 .927 pin manley flat tops 11.5 to 1 LSM cam .400 LS lobe(.640 ) 266/272 @.050 114 LSA hydraulic roller Manton 3/8 pushrods ATI dampner Charlies 8QT oil pan
CNC ported 6.1 heads from MCH Pac 1219 beehives 150/400 open Sharadon rocker shaft tie bars and collars Drag Pack intake Fast EFI
[Re: 440Jim]
#1236550
05/20/12 10:26 PM
05/20/12 10:26 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Congrats, Rick! That thing is gonna be an animal with some more tweaks man! Happy to hear its going in the right direction for ya! Keep at it.
Wes
"Any fool can know. The point is to understand"
- A. Einstein
[Re: Dragula]
#1236552
05/21/12 12:59 AM
05/21/12 12:59 AM
Posts: 1,030 ohio
67mprfan
ohio
congrats rick car looks good
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: racer_amx]
#1236556
05/21/12 08:52 AM
05/21/12 08:52 AM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
Nice Rick! Very good numbers for the first session of hits on a completely new setup! Like with anything, more tuning will have that thing flying! Question, what does the car weigh? I hope our 5.7 carb motor lays down solid numbers as you did first out. I'm still at stage that I am flipping coin on crank stroke decision. Will be ordering internals by next week.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
