What head gaskets w/ Eddy aluminum heads? #1236333
05/20/12 10:55 AM
05/20/12 10:55 AM
illinois
bigblk66_coronet Offline OP
illinois
Well looks like a have to tear a head off and figure out what my problem is. Which is the best head gasket to use with Eddy aluminum heads? Its been 8 years since i put them on and cant remember what they were?.........Thanks....Joe.....and its for a 440
Re: What head gaskets w/ Eddy aluminum heads? [Re: bigblk66_coronet] #1236334
05/20/12 11:26 AM
05/20/12 11:26 AM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
COMETIC MLS
Re: What head gaskets w/ Eddy aluminum heads? [Re: bp27] #1236335
05/20/12 12:03 PM
05/20/12 12:03 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
FelPro 1009s on mine have been bulletproof up to 13:1.
Re: What head gaskets w/ Eddy aluminum heads? [Re: topside] #1236336
05/21/12 01:26 AM
05/21/12 01:26 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
what compression ratio? the 8519pt1 is a good gasket and inexpensive.
Re: What head gaskets w/ Eddy aluminum heads? [Re: bp27] #1236337
05/21/12 09:28 AM
05/21/12 09:28 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
COMETIC MLS
Re: What head gaskets w/ Eddy aluminum heads? [Re: topside] #1236338
05/21/12 03:13 PM
05/21/12 03:13 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Re: What head gaskets w/ Eddy aluminum heads? [Re: justinp61] #1236339
05/22/12 12:52 AM
05/22/12 12:52 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I have no idea whats going to work best for you but when I build something often the head gasket is picked not only for its quality but for its thickness (or thin-ness!)
Re: What head gaskets w/ Eddy aluminum heads? [Re: radar] #1236340
05/22/12 01:15 AM
05/22/12 01:15 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I am using the cheap blue felpros that come in the rebuild gasket kit. No issues even pulled a head off and re-used no problems.
Re: What head gaskets w/ Eddy aluminum heads? [Re: topside] #1236341
05/24/12 08:20 AM
05/24/12 08:20 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
Running 10 years, no problems with Felpro 1009
