Re: 572 Hemi....take a stab at the numbers....
[Re: Evil Spirit]
#1235865
05/22/12 05:41 PM
05/22/12 05:41 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Thats because you are not taking into consideration the displacement of the OPs engine.
What cubic inch were the Hemis you built, and what cams did you put in them? How do they run, or how well did they dyno?
As someone else posted, I wouldnt consider a 270 cam in a 572 a "big" cam.Your conventional thinking of a .650 is simply too small for this application. I'd say Bullet hit it pretty well. Also notice the 112 LSA.
RIP Monte Smith
[Re: CompWedgeEngines]
#1235866
05/22/12 06:45 PM
05/22/12 06:45 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Cam is definitely not too big. Mine is 276/284 at fifty, 112 LSA, 11:1 compression, and the same cubes. 185 psi cranking and on 93 octane pump gas. Mine does have less lift though.
#1235869
05/23/12 12:06 AM
05/23/12 12:06 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
I had Bullet spec my cam out also. I told them that the best commonly available fuel here is 89.5 octane. I also wanted something that was easy on the valve train. My compression works out to 10.5-1, my dynamic compression is 7.57-1 with 148psi cranking. 605 ci the cam specs out at 757/676 288/292@.050 on a 113 center. I have never talked to anyone that didn't like the cam they got from Bullet. In almost all cases people said their new Bullet ran better and quicker than with their old cam. I have no doubt I'll like their cam. Dave
